Joe Miranda
Titanium
- Oct 19, 2004
- Elyria Ohio
All - I need your help...I have an '04 Ford Explorer that is in really nice shape and I would like to keep it for another couple of years. Here's the thing, I had to replace the ABS module on it and they are discontinued. So I found a compatible unit from a salvage vehicle and confirmed that it would work with the local Ford dealer. But after installing the unit (which fixed the problem) I am now getting a mismatched VIN code that also disables the ABS and the 4x4. I have taken it to two different Ford dealers to reprogram the ABS module and they are unable to clear the VIN out of it and they even called the Ford motor tech hotline and they are saying too bad so sad we don't support that vehicle because it is too old.
The car is driveable as it is but I want the 4x4. I found a guy in California that said if I had kept the old ABS module he could have taken the info off the chip and transferred it to the new unit and all would be golden - I didn't save it.
I have called all over the US and cannot find NOS. If anyone knows of someone that can wipe the ABS and re-program I would really appreciate that info. Thanks.
