OT:Help with plumbing leak, best fix for this fitting, W/pic
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
    May 2005
    Alabama
    539
    38
    Default OT:Help with plumbing leak, best fix for this fitting, W/pic
    I've only messed with copper and PVC plumbing before, I just found a spewing leak in my crawlspace, what kind of plumbing is this and whats the best way to fix it? The tubing has a marking inside a rectangle box that says NSF-pw. The house was built at the end of 1996. The big tubing is about .860 O.D. and the small top tube is .625 O.D.,the leak is on the left side in the picture and is spewing straight up against the floor, any advice would be helpful, thanks.
    Mar 2009
    Eureka, CA
    3,908
    814
    1411
    Cuda,
    I believe that is a PEX fitting. It takes a special installation tool to attach the plastic tube to the fitting but I think other than that, it's a real easy repair. I would call a plumber for sure.
    Stuart
    Jun 2007
    Oregon
    80
    Hard to tell from the picture but if that pipe is gray colored it is possibly part of a class action recall/lawsuit, you likely have other leaks as well. Definitely get a real plumber involved.
    Jun 2006
    Kansas
    1,479
    281
    539
    Yep it is PEX, most of the time good stuff never seen one leak, I made a good crimper out of a pair of old 24" bolt cutters to crimp the copper rings.
    May 2005
    Alabama
    539
    38
    Quote Originally Posted by eko View Post
    It's white tubing, not the bad polybutylene stuff "I think" I really don't want to call a plumber even though I know a plumber, I'd rather fix it myself. I'll even buy a tool if needed.
    Mar 2009
    Eureka, CA
    3,908
    814
    1411
    Cuda,
    See if you can borrow or rent a PEX crimper from your local hardware store or tool rental outfit.
    http://www.pexinfo.com/#connections
    Stuart
    Feb 2001
    Redwood City, CA USA
    5,110
    200
    1012
    You may be dealing with bum brass. There are recalls and class actions afoot. The issue for at least some of those cases is that the zinc leaches out - "dezincification".
    Jul 2008
    Asheville, NC
    2,468
    1258
    1201
    I would get a new T and some crimp rings, rent or borrow the crimper, and replace that one. If there is enough slack to cut off the connector and crimp on to the uncrimped PEX, that would be best. If you can't, cut the crimp rings off with a Dremel tool without cutting the PEX (yeah, right) clean out the inside with a rolled up rag or bottle brush and crimp on the new T. You might check your water pressure to see that it is only around 50 pounds. If it is above that check / replace the pressure reducing valve if city water or your pump shut off switch. Our city water pressure can be as high as 200 pounds.
    My local Home De Pot has crimpers for rent, or for sale.
    I have seen push on fittings that are supposed to work on copper or PEX. I'm skeptical, maybe someone here has experience with them.
    While you are down there crawling around like a snake, check all the other ones you can see. If most of them are leaking you may have a recall, or sue somebody situation.
    If the ones you can see are leaking, the ones in the walls are probably leaking.
    Hopefully you have just one Friday-going-home-time connection.
    Paul
    May 2005
    Alabama
    539
    38
    I only saw one leaking, although some are behind walls. I was reading about something called a Shark Bite push on connector that uses a O-ring and a stainless lock ring, sounds like that may be the way to go.
    http://www.pexsupply.com/SharkBite-P...ittings-588000
    http://www.homedepot.com/webapp/wcs/...atalogId=10053
    Apr 2008
    Rapid City S.D. USA
    211
    The crimp on the left is not installed properly. Menards has pex crimpers for 9.95 get a new t and 3 crimps and redoit.
  11. Likes Bobw liked this post
  12. #11
    Feb 2005
    Fishersville VA
    1,769
    6
    71
    Could be a poor/bad crimp,leak started, got worse etc.
    it is critical that the band be crushed to a specific size.
    If you rent,buy a tool, test the crimp size,(uses a gauge) before you crimp your actual line.
    Good crimpers have an adjustment.
  13. #12
    Apr 2009
    Phoenix, AZ
    30
    I have used the shark bite fittings to install a water line for an ice maker just make sure you have some slack and you need to cut the line back to an area where it has'nt been flared out they work pretty good
  14. #13
    Jan 2009
    S FL
    880
    239
    210
    i would use shark bite fittings instead of PEX. i hate that pex stuff. i talked to a real plumber and he only uses copper pipe never pex, copper is cheaper in the long run and wont leak like that.
  15. #14
    Aug 2005
    Tacoma Washington
    1,344
    87
    127
    It looks like you have a corrosion issue as well. You might want to check and mabey replace the brass as well. Looks like it has been electrically reacting with the steel bands.
  16. #15
    Sep 2005
    il.
    6,676
    31
    1242
    shark bite is the tits
    just cut out a 2 foot section and redo it
  17. #16
    Feb 2005
    Medway, Ohio
    1,353
    147
    114
    I think I know why plumbers don't like that stuff. I can completely replumb an old house in a days time. All my connections are at the hot and cold manifolds and the other connections are at the point of use. A separate line for everything including a shut off valve for each line. I have the grey line that was recalled. It has been in for 18 years and never a leak. The crimp rings are copper. My advise would buy the crimper and a few rings and fittings in case you need to change something in the future. Kenny
  18. Likes sfriedberg, Bobw, Yan Wo liked this post
  19. #17
    Apr 2004
    Modesto, CA USA
    7,378
    1282
    the crimp rings are copper. they do not look like any of then got crimped down tight enough. They also make stainless crimp rings(different design) that use the same tool for all common sizes. Make sure you buy pex fittings not hose barb stuff. for a small job like this it may be cheaper to use sharkbite rather then buy thew crimper tool.
    Lowes and Home depot are getting rid of the crimp rings, crimper and fittings and switching to only sharkbite. The shark bites for this job will probably cost over $50. with true pex fitting and rings might be $10 plus crimper cost around $50 They do sel lthe pex in 20 foot pieces, keep it out of direct sun.
    Bill D.
    I think you will need a new tee and three nipples
  20. #18
    Feb 2020
    Ohio
    You can contact Moors Ville Well Drilling company for free consultancy and to get their best well drilling and plumbing services in the whole US region. Their contact number is mentioned on their website. You can find their website link attached below:-
    Well Drilling Mooresville
    Well Drilling Davidson
    Cornelius Well Drilling
    Concord Well Drilling
    Huntersville Well Drilling
  21. #19
    Jan 2014
    Temecula, Ca
    3,201
    1383
    4189
    go to hell, Robert
  22. Likes Bobw, Hodge, Joe Rogers, Rudd liked this post
  23. #20
    Jan 2005
    Houston
    6,139
    718
    2880
    Call a plumber. lol.
    You can fix that as suggested for little time and trouble...who calls a freakin' plumber? Women, that's who.
  24. Likes Bobw liked this post
