Just to pick two average (i.e. not really high performance) examples... Mazda Miata and Mercedes SLK sports cars... I've wondered for years if it makes that much difference in the engine size/weight and acceleration potential for these to have high compression engines vs conventional "regular gas" engines ? In other words could the engines in these two be redesigned such that the size/weight would be just a tiny bit more.... or would the "regular gas" engines need to be larger and heavier enough to negatively effect the whole picture ?
Another issue, if one uses regular gas in modern vehicles that are supposed to use premium gas, the timing is automatically retarded to eliminate engine knocking. And damned if I can tell any difference in acceleration, mpg, or engine vibration using regular in one of these. But then one reads that long term there could be engine damage using regular in a vehicle meant for premium. But assuming no knocking, I never read exactly what this damage might be. Thoughts ?
