I found this out the hard way....just a warning to make damn sure if you buy one it has provisions for a backup battery, as otherwise you loose a lot of tedious programming even if the power goes out for 5 minutes....or you have to shut the system down for maintenance or whatever. I'm posting this because I was dumbfounded any company would be so stupid to design one like that in the first place...expecially considering the typical plain jane digital thermostats that don't need programming, DO have provisions for batteries.
What I mean is, how bizarre to make a thermostat that depends on complex programming (including the type of equipment it is connected to and twenty other parameters, plus WiFi connection info) that has no battery backup after decades making Plain Jane digital thermostats that require no programming at all, but yet include provision for two AA batteries anyway !
The icing on the cake being confusing terminology in the parameter choices....like is this gas or electric furnace ? "electric furnace" ?? Why can't they say "heat pump" like everyone else in this country ?
So, this is a rant, but mostly a warning to be careful which Honeywell programmable WiFi enabled thermostat you buy. This one was a something 6500 model from Lowes.
