OT- Hot Tank Solution
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Jan 2008
    spokane
    877
    5
    85
    Default OT- Hot Tank Solution
    Anyone have a good homemade hot tank solution. Small parts 5gal.bucket. Also a paint stripper paste/gel.
    Oct 2012
    Virginia
    10,268
    5843
    4626
    Quote Originally Posted by blake in spokane View Post
    What metals?
    Oct 2009
    Oregon
    4,081
    4382
    2053
    Simple hot tanks usually run straight lye.
    You buy it in powder form from your local chemical supplier in 30 gallon kegs.
    You will dissolve a lot of powdered lye into 200 degree water to make it "hot" and strip ferrous stuff quickly.
    If you plan to put non-ferrous stuff in there then a hot tank is the wrong tool. Aluminum formulations don't like just soaking overnight. They need pressurized spraying to work because, well, they lack lye.
    Apr 2012
    New Zealand
    662
    160
    189
    TSP (trisodium orthoophosphate) is very good as a saturated solution, either hot or cold. Removes paint and aluminium doesn't dissolve instantly although it does etch and pit in time.
    Also, washing soda as a hot solution.
    Both will remove paint and grease and are much safer than lye.
    Jan 2007
    Florida
    1,102
    132
    403
    Zep
    9878
    actual hot tank stuff. also in a 5 gal can maybe carb cleaner would work for you?
    Oct 2009
    Oregon
    4,081
    4382
    2053
    Quote Originally Posted by Greenwud View Post
    What is unsafe about lye? Yeah, it will dissolve your skin if you leave it there long enough, but so will Coca Cola. I've been up to my armpits in the stuff and got high concentrations in my eyes before. Really wasn't that bad. Lye is pretty safe compared to most other chemicals IMO.
  7. Likes dalmatiangirl61 liked this post
    Apr 2004
    Modesto, CA USA
    6,742
    1122
    sand works well. Not much problem with spills or splashing.
    Bill D
  9. #8
    Oct 2012
    Virginia
    10,268
    5843
    4626
    Quote Originally Posted by Garwood View Post
    I count you a brighter guy than average.. but "What is unsafe about lye?" Must never have been exposed to serious STRONG Lye, then?
    Mind, our outfit used it by the CONEX container, 100%, "Anhydrous" technical grade flake, mixed with "just enough" water to fast-strip CO2 molecules from high pressure air, so about as concentrated a slurry as could be mixed and still be pumped @ 5 HP.
    Side-effects do tend to bias a body. Dissolve rubber sandals, combat boots, skin, muscle, dead animals etc. before you know it has even started.
    And you do have me wondering just what it is you consider "most other chemicals"?
  10. Likes tdmidget liked this post
  11. #9
    Oct 2009
    Oregon
    4,081
    4382
    2053
    Quote Originally Posted by Monarchist View Post
    I have a 30 gallon drum of pure sodium hydroxide I bought from MT Hood chemical for my hot tank. I don't think it gets anymore pure than 100% pure.
    One of my hot tanks came with the ZEP product mentioned above. I gave it away. Didn't work anywhere near as well as pure lye I learned to use in the race engine shop I spent several of my late teen years in.
    It doesn't immediately burn you. It dissolves your skin and you can tell it's happening. I've boiled an arm to grab something important out of a 200 degree tank at saturation with lye, washed my arm off and it was fine.
    In a dark, dry cabinet I have a gallon of Hydroflouric I keep next the DDT.
  12. #10
    Sep 2007
    Woodinville, WA
    1,774
    205
    376
    Pure isn't the issue. It's "concentration".
    2 tsp per gallon - fine... Mix 30lb with 5 gallons of water and stick you arm in that. See what's left after 30 seconds.
    How much per gallon are you putting in?
  13. Likes Monarchist, MetalCarnage liked this post
  14. #11
    Oct 2009
    Oregon
    4,081
    4382
    2053
    Quote Originally Posted by Lakeside53 View Post
    20 gal powder sodium hydroxide to 150 gallons water is about where that was at. I would call that a pretty heavy concentration. You can watch the powdered lye reach a point where it doesn't readily "go into" the water anymore. I'm not chemist, but that point is where I was always told you are at max cleaning potential. Seemed pretty safe to me and cleaned parts well. Much rather play with lye than nasty acids or chlorinated stuff.
    My experience has been temperature had the greatest effect on cleaning action past a certain point of concentration. over 150 degrees was important. almost boiling was amazing, but the electric bill was staggering and I found a balance between temp and cost was required.
  15. #12
    Apr 2012
    New Zealand
    662
    160
    189
    Lead paint argument all over again, but it comes down to basic risk management and a little chemistry. Guys who aren't lucky with lye in the eyes don't see so well; it's generally regarded as fairly unforgiving stuff.
    Risk/benefit isn't so good either, as lye reacts with carbon dioxide in the air to form sodium carbonate; like all reactions, it's faster at temperature. One may as well start with sodium carbonate and avoid the real risks involved in mixing lye with water.
    Essentially, there are chemicals that as as effective that carry lesser risks. Some of them also have a longer effective working life.
    If you are confident handling chemicals, that's good-your informed choice- but for those that aren't, lye can be bad news fast.
  16. #13
    Oct 2013
    New Jersey
    1,054
    883
    The strongest caustic solution (lye) you can buy is 50% and it is a pain to deal with because it freezes at 68F. We use caustic in the waste treatment business because nearly every waste stream has low pH and we need to bring it up. I have had a drum of 25% or 50% caustic on every job I've done in the past 15 years. It is very nasty if you get it on your skin it burns like hell, and get it in your eye you will be blind. 25% caustic doesn't freeze down to about 0F so is much easier to work with.
  17. #14
    Mar 2001
    Gaston, Oregon USA
    1,521
    6
    338
    Well visiting an old thread, and am wondering if anyone has any real experience with the ZEP hot tank solution. The company I have been buying from for thirty five years- Mt. Hood Chemical Corp has disappeared. I bought several of their products including STRIP their hot tank solution. Long ago, I did make my own using sodium hydroxide, and TSP. Worked well. These days you go on the internet searching for hot tank solution and the top company is in England and the second company is in Canada, Has the US completely gone off the rails, not wanting to sell chemicals? I used powdered sodium hydroxide, not any sort of liquid. So I'd say it was 100%. Someone having caustic FREEZE, must be buying a liquid.
  18. #15
    Dec 2012
    AUSTRALIA
    1,889
    9
    580
    Has Turco Products gone too?
  19. #16
    Jan 2011
    BFE Nevada/San Marcos Tx
    1,043
    915
    542
    If you want a paste/gel, dissolve 1lb of lye into 5 gallons of water, then stir in corn starch till you get consistency you want (1 to 2 lbs). You can make it thick enough that it will stick to a vertical surface. It works best hot (freshly made).
  20. Likes Limy Sami liked this post
  21. #17
    Aug 2005
    Tucson AZ
    6,276
    9371
    2939
    Quote Originally Posted by garyhlucas View Post
    Do you know what this "-" means? As in "minus 68 degrees"? Duhhhhhhhhhh
    D
  22. #18
    Feb 2004
    peekskill, NY
    24,218
    4413
    [QUOTE=Garwood;3120068]What is unsafe about lye?
    To paraphase that laser safety sign:
    DO NOT PUT LYE SOLUTION IN REMAINING EYE
  23. #19
    Jul 2007
    UNITED KINGDOM
    4,716
    2484
    2289
    Quote Originally Posted by tdmidget View Post
    D
    I suspect that Gary was well aware of what the minus sign is. However, he meant PLUS 68°F. Lookey here.
  24. #20
    Jan 2007
    Florida
    1,102
    132
    403
    Quote Originally Posted by [email protected] View Post
    i used it for many years but got rid of the hot tank in 2005 and haven't used it since. used it on engine blocks, heads, etc
