OT How to Keep Paint Warm in Service Truck
Page 1 of 3 123 LastLast
Results 1 to 20 of 55
    Nov 2009
    Michigan USA
    1,133
    84
    236
    Default OT How to Keep Paint Warm in Service Truck
    Hello,
    Getting tired of removing the 10 paint cans form the service truck every night in the winter. Does anyone know of a heated 12 volt solution so the cans can stay in the truck and still be usable the next day?
    Thanks for the help.
    Nov 2008
    Madera county california usa
    2,496
    21
    624
    That would require lots of heavy batteries.
    Better and easy is simple, a couple 100 watt lights in with paint and plug in when parked.
    Just enough to keep warm.
    Too much could pop a can and cost more to heat.
    Aug 2004
    Virginia
    2,414
    179
    954
    I assume these are gallon cans right? I see you live in a pretty cold place so I don't think your battery is going to provide enough capacity to keep the paint warm. Of course you could build an insulated box for your paint and then it would probably work. Would it be easier to have a cord to run power to your truck at night. If you had 110v then the sky is the limit as to what you could use to keep the paint from freezing. There are rubber greenhouse mats that are very tough and cheap. You could set your cans on that and they would stay toasty in any kind of weather.
    Jun 2012
    Michigan
    10,602
    3605
    3756
    A bubdy heater will run 6 hours set at low.. dont know how safe that might be.
  5. Likes digger doug liked this post
    May 2005
    Interior British Columbia
    2,405
    249
    755
    Webasto Heater.
    Fuel fired heater that will provide warmed coolant, and/or warm air.
    Not cheap, but Overseas made clones are out there. Or find a heavy truck wrecker, and see what he has in stock.
    Oct 2010
    Oregon
    5,213
    4598
    1899
    Start with an insulated cooler so you're not trying to keep the whole Upper Peninsula warm at night. Use an incandescent light bulb (pre-LED, pre-CFL). Depending on the size and efficiency of the cooler a 40W or 60W bulb might suffice. Put a short cord on the bulb with a plug outside the cooler body, and seal the hole for the cord. Use an AC extension cord from a shop or house outlet to the cooler cord. If your location is cold enough to use block heaters, you can obviously use the parking outlet for your truck's block heater. Unplug the extension before you drive off in the morning!
  8. Likes JoeE. liked this post
  9. #7
    Virginia
    29,060
    7561
    9036
    Quote Originally Posted by athack View Post
    Hello,
    If you cannot bring the whole vehicle indoors, see about renting heated space for the winter.
    Otherwise, buy or fab some sort of roll-out rack so you can more quickly and EASILY take the paint indoors and back out.
    Make use of heat already PAID for.
    All else, your winters?
    Only worthwhile if you need it all day on jobsites, too. As you may. If an extension cord can be had, a small, cheap, DeLonghi style oil-filled space heater might do yah and make for a more comfortable truck as well.
    Whole-vehicle combustion heater choices also abound. They beat all Hell out of an already cold-stressed bettery gone flat.
  10. Likes digger doug liked this post
  11. #8
    Oct 2005
    16,641
    What are you doing that you head out each day carrying qty (10) cans of paint ?
    BTW you never defined "paint" nor "can".
  12. #9
    May 2002
    South Central PA
    13,730
    2340
    3605
    Maybe a large truck driver warmer/cooler
  13. #10
    May 2019
    653
    187
    284
    I'm interested
  14. Likes digger doug liked this post
  15. #11
    Jan 2015
    Missouri
    1,086
    212
    680
    Drive it to Florida
    You can take me too
  16. #12
    Apr 2004
    Modesto, CA USA
    7,186
    1225
    Paint should be the same temperature as the surface being painted.
    Bil lD
  17. Likes Greg White liked this post
  18. #13
    Mar 2005
    Kansas
    7,706
    459
    3628
    Use oil based paint.
  19. #14
    Jan 2007
    Flushing/Flint, Michigan
    8,379
    437
    6894
    Is this a serious question.
    What part of Michigan?
    12 volts off of the truck/van battery will not do it overnight at any cold here..
    A good blanket and a plug in heater will keep a comfy 70 if the bottom is off the floor with a piece of styrofoam underneath.
    A 12 volt heater can not heat the cabin of even the smallest car here in Michigan in winter time. The wire would have to be huge and the biggest battery dead in 20 minutes.
    To hold 50 to 60 in a normal van with electric takes about 8-10 amps at 120 volts continuous in the winter here in mid-Michigan. (yes I camp in the winter)
    Insulation is your friend, I wonder how a plug in electric blanket with some insulation down or just wrapped under would work?
    Bob
  20. #15
    Virginia
    29,060
    7561
    9036
    Quote Originally Posted by gbent View Post
    F**ks sake, ten one-gallon tins? Two hands, two at a go out of or into the truck, folding handle platform cart to a warmer space?
    One go each way, each day?
    If that's some kind of a "show-stopper", just go and find a better job you can actually HANDLE.
    Economy is doing well enough f**king with cold paint in the freezing nawth can go onto some hungrier guy's menu.
    Or... sever it.
    Sub-out the painting as a seperate task to wotever ELSE earns the crust. Turn it over to a pro at it who already has proven inclement weather solutions.
    God didn't invent cold weather just last week, did she?
  21. #16
    Jan 2007
    Norfolk, UK
    19,309
    14774
    14927
    Hot water bottle and read it a bedtime story.
  22. Likes digger doug liked this post
  23. #17
    Virginia
    29,060
    7561
    9036
    Quote Originally Posted by Limy Sami View Post
    FEELTHY bedtime story, yah can even skip the hot water bottle.
    Averyone KNOWS how promiscuous high-libido PAINT can be.
    Always wet. Envaginates anything gets NEAR it. Takes its sweet old time to dry once laid-on thick or thin either one, "marks" it's conquests, goes proudly nekkid thereafter.
  24. #18
    Oct 2005
    16,641
    Quote Originally Posted by Hardplates View Post
    I'm interested
    I really think you are seeking hot butter....
    YouTube
  25. #19
    Nov 2013
    Eastern Massachusetts, USA
    4,975
    4917
    4889
    I 100% agree with the posters who say any heaters need to be powered by 120vac.
    If you start with a reasonable temperature before the vehicle is parked fairly modest heat along with insulation should do the job. I would suspect heat tape for pipes wrapped around the cans would be most effective but a heated mat would also work. Even one of those rod heaters as used for cabinets and gun safes tucked between two rows of cans plus insulation should do it. You'll need insulation under the cans as well as in a box or "tent" to keep the warm air in. Even a mover's quilt provides some insulation. I use one over my attic fan in addition to other measures in winter.
    10 cans isn't really a huge volume to heat, especially if you get creative and double stack the cans. If it were me I'd probably make a heavy duty "wire" rack out of rod to lift the cans off the floor and allow them to stack in close proximity. A single rod heater in a cradle underneath the center of the cans along with a good insulating blanket should keep them warm overnight. Heat rises and I've personally seen how cold a van floor can get while riding in the back of a "customized" van in winter that had no insulation under the carpet.
  26. #20
    Nov 2009
    Michigan USA
    1,133
    84
    236
    Thank you everyone for the helpful replies. Sounds like an insulted box with some kind of heat element will be the way to go.
    I also like the Heatso Heaters that run off the vehicles fuel supply.
    Thanks Again!!
