OT- Hydraulic hose gurus - does this fitting exist ?
Results 1 to 18 of 18
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,459
    2924
    5744
    Question OT- Hydraulic hose gurus - does this fitting exist ?
    Female British parallel #4 fitting for #6 hose ? ( FWIW, that is what NAPA guy says I need anyway....)
    Jan 2008
    New Hampshire
    265
    120
    75
    My Gates catalogs only show 4-4 or 6-6 in female and male hose ends. Likely you’ll be using adapters to make it happen. Why not just use #4 hose? It’ll be choked down at the fittings anyway.
    May 2017
    FINLAND
    2,157
    586
    999
    Quote Originally Posted by Milacron View Post
    Sealing style? 60 degree cone with o-ring in the cone would be the most common for BSPP hose fitting (next most common being HIAB style with flat sealing face)
    https://www.hidrobalt.lt/uploads/use...ngs-pdf-EN.pdf
    Common enough that nearest hydraulic shop in here would have one.
    Nov 2007
    marysville ohio
    9,884
    2820
    6590
    Do you have a Parker store around there?
    Jan 2012
    Midland, Texas
    1,563
    565
    800
    Guess you could make one--if you weren't selling all your equipment...
    Dec 2000
    51,459
    2924
    5744
    Quote Originally Posted by e-fishin-c View Post
    Because the other end attaches to a Swiss made pump with slightly larger metric fittings ( which I would be using at the pump end of the hoses)
    Jan 2008
    New Hampshire
    265
    120
    75
    If you strike out at your local places I could make up an adapter. Here’s a sample of my custom fittings (before TIG welding)952c6be9-ab50-4ecc-8ac0-5d3394da3615.jpg
    Mar 2001
    New Haven, CT
    3,524
    44
    694
    Download the parker firing finder app on your phone or google it and use the web app. Best tool out there for finding fittings ever. Once you get the parker part number most distributors can help you find it
    Dec 2003
    Washington
    4,871
    2404
    4424
    I worked in a hydraulic fitting and hose house from age 15 to 18 . . . All hose is base 16 size, so #4 fitting is 1/4 inch and #6 hose is 3/8 inch.
    Are you looking for a pressure rated fitting? Low pressure barb? Reusable? Crimp on? What kind of hose?
    If low pressure, this will work . . . McMaster-Carr
    Feb 2013
    Northern califorina, usa
    347
    5
    122
    Just as e-fishin-c states regardless of the hose I.D. size you use it will still only allow the flow volume of the end fittings you use at a given pressure. As the pressure increases so will flow volume, limited by pressure and flow restriction.
    Number 4 is 1/4" and number 6 is 3/8". You could use larger I.D. hose but in the end your still pushing that oil through a 1/4"
  11. #11
    Langley, B.C.
    1,767
    386
    1036
    ...If you strike out at your local places I could make up an adapter...
    Yup, back in the 80s when all the Japanese excavators started hitting the west coast we made a ton of adapter
    fittings. Dealers wanted obscene amounts of money for replacement hoses and you couldn't buy many metric
    fittings from the aftermarket suppliers. We made a ton of adapters for two or three years till the aftermarket
    guys caught up. After a while the demand petered out--haven't made one in years...
  12. #12
    Jan 2008
    New Hampshire
    265
    120
    75
    Quote Originally Posted by dana gear View Post
    ............You could use larger I.D. hose but in the end your still pushing that oil through a 1/4"
    And worse, the inside of a #4 crimp fitting reduces it to around .125” ID through the nipple. After crimping some #4 ends can barely fit a .125” punch through.
  13. #13
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,158
    451
    1081
    Hey DT
    I loooked at Parker 4300 tube fittings catalog for a bit.
    They have only BSPP to NPT adapters, nothing BSPP to crimp-hose.
    So you'd have 2 steps, BSPP to NPT and NPT to crimp-hose, hopefully other end is a swivel (??), OR if its something you care about long-term, get both ends to JIC male fittings. Then you can get a double female JIC swivel hose made anywhere in America, leak-free, no fuss-no muss, super easy installation.
  14. #14
    Dec 2000
    51,459
    2924
    5744
    Well aware of that but for this application the flow was already appropriate for the machine (a Myford cylindrical grinder) at 1/4" hose ID. Bottom line is I'm trying to substitute a Swiss made hydraulic pump for the original Myford pump (that seems to be kaput)
  15. #15
    May 2017
    FINLAND
    2,157
    586
    999
    Here you go
    BSP Female Swivel (FBSPX)
    eye-watering price but it's in US
  16. Likes Milacron liked this post
  17. #16
    Mar 2009
    5,602
    103
    1084
    Out here a trip to the local Parker store would get you the answer and they could repair your hose or get you a new one at whatever length you want.
  18. #17
    Oct 2010
    Dewees Texas
    2,605
    29
    766
    I can go down to Poth, Texas population 2000 and get Ken at Ken's Farm Parts to swage together any fitting I bring him. Like someone else mentioned if your shop was not all tied up in the sale you could make the ends your self and get them swaged together at many farm supply stores, as well as at hydraulic supply houses. I just built some custom ends for cattle water trough hoses and Ken swaged them together for no charge.
  19. #18
    Oct 2010
    Dewees Texas
    2,605
    29
    766
    If your machines are tied up with the sale, surely as many friends as you have on PM someone close by could make the ends you need. Little Giant water trough hoses I made are in the photo. Made 11 of these.
