vmipacman
Cast Iron
- Nov 21, 2014
- Virginia, USA
I have a Daikin V38A2RX-95 pump on my hydraulic unit. It operates at 1200psi. The pump is quite normally, but will periodically make what i would describe as a "pang" noise that resonates through the system and decays in volume for about 10 seconds. Then it will be quite for 20-30 seconds (or a few min) then make another "pang" that dissipates. Otherwise it functions fine, and I believe this is not a new sound, just new ears.
What I know:
-I am not sure that the sound is related to pressure demand, but it stands to reason, so maybe something related to internal bypass?
-It seems to have enough fluid in the tank, i.e. sucking in air was my first thought.
-There is a weeping leak under the pump that I do not think is related to the sound.
-All I could find was this diagram, but on page 2 these are some cutaways for the V38.
https://www.daikinpmc.com/en/catalog/GK247A_A-040SB.pdf
Does anyone have experience with hydraulic pumps/systems that might know where to start looking? I focused on the pump since the sound seems most intense there and at the outlet.
Thanks!
What I know:
Thanks!
