ot: Insulating material for inside of a smoker/bbq pit?
Results 1 to 20 of 20
    Apr 2007
    Dublin Texas
    2,591
    1408
    917
    Default ot: Insulating material for inside of a smoker/bbq pit?
    Started a new project this weekend. I have a 250 gallon propane tank that I'm going to make into a smoker/bbq pit. I filled it full of water and cut a window into it on Saterday. I'm going to put a tail section on it so that it looks like a big bomb. I'm going to build a trailer so that I can stand the thing vertical and have the smoke come out the tail. Is there a material that I can insulate the id with to keep from burning the paint off without killing everyone that eats out of the thing? The walls are 1/4" thick.
    Any ideas?
    i_r_
    Jul 2011
    Navasota / Whitehall Texas
    3,570
    2617
    1977
    No need to paint the inside or insulate it.. It will have a coating of meat fat and smoke soon enough..
    When that gets too thick burn it out or scrape and clean it...
    Paint the outside with hi temp Bbq or engine paint or form a covering out of metal so that there is an air space between the tank and outer cover.
    Sent from my SM-N900V using Tapatalk
  3. Likes J Gilles, JoeE. liked this post
    Jan 2014
    Temecula, Ca
    2,749
    1246
    3568
    Asbestos?
  5. Likes JoeE., loggerhogger liked this post
  6. #4
    Feb 2016
    Washington
    183
    425
    86
    Quote Originally Posted by swatkins View Post
    Swatkins has the right idea here. I built one last summer out of a 325 gallon tank and used the high temp paint. It is holding up well, but it is kept under an overhang. It takes while to get up to temp, but it will hold pretty steady. I feel like the biggest thing to focus on is keeping the gaps as small as possible and tuning the insides to make the most of the hot air.
  7. #5
    Feb 2005
    Akron, OH
    1,824
    277
    1368
    If you really do need to insulate it calcium silicate looks pretty harmless.
    Effects of the inhalation of dusts from calcium silicate insulation materials in laboratory rats. - PubMed - NCBI
  8. Likes JoeE. liked this post
  9. #6
    May 2006
    Illinois
    230
    88
    38
    Depends on how involved you want to get.
    I built one with a double side-wall that has rock wool insulation between the layers of steel. Takes a small amount of fire to heat it and it holds the heat very well. You can lay your hand on the outside when its at temp.
    gm
  10. #7
    Nov 2006
    Camarillo Ca
    472
    24
    112
    You can always used fire clay. Bob
  11. #8
    Dec 2008
    IL/WI border
    3,184
    1001
    922
    Shuttle insulation tiles are pretty good.
  12. Likes JoeE., tdmidget liked this post
  13. #9
    Aug 2012
    California, Central Coast
    3,331
    2153
    1296
    A buddy of did a pizza oven kit and it came with kaowool or similar to cover the "igloo" with. It does an amazing job of holding in the heat. gmoushon idea or rockwool is probably just as good. Use less wood and keep most of the heat inside. It would need to be contained though, eithe in between two layers of metal or you could line the inside with it and then fireclay over that, like relining a forge or kiln.
  14. #10
    Jun 2015
    CANADA
    Ontario
    398
    915
    235
    Quote Originally Posted by MichaelP View Post
    Apparently not.
  15. Likes Pathogen, JoeE., MichaelP, Comatose, tdmidget liked this post
  16. #11
    Mar 2005
    Kansas
    7,412
    424
    3394
    Shuttle tiles are very good insulation. The problem is they are fragile.
  17. #12
    Jul 2005
    Eastern PA
    921
    128
    598
    Paint the exterior with flat black hi temp stove paint. Works very well and lasts a long time. Besides that on a smoking bomb the look would be titties and beer....Bob
  18. #13
    May 2006
    Seattle
    1,859
    35
    345
    Umm - heat rises, right? How are you going to get the smoke coming out the bottom?
  19. #14
    Dec 2004
    uk
    14,057
    4552
    6699
    Quote Originally Posted by gbent View Post
    Yeah well just don't throw the sponge at them when you wash the thing and you should be fine.
  20. Likes MichaelP liked this post
  21. #15
    Mar 2006
    Washington
    848
    92
    52
    Quote Originally Posted by i_r_machinist View Post
    Any ideas?
    i_r_
    Does the propane stink burn off in the first fire?
  22. #16
    Oct 2005
    14,552
    Quote Originally Posted by metalmagpie View Post
    There are several top loading wood and coal stoves out there.
  23. #17
    Jun 2015
    CANADA
    Ontario
    398
    915
    235
    Quote Originally Posted by jmead View Post
    Bleach will kill the odorant
  24. Likes jmead liked this post
  25. #18
    Dec 2015
    Illinois
    387
    126
    216
    In my mind the tail section is up as if it was dropped from a plane, so the smoke would be rising. I might have misunderstood though.
  26. Likes i_r_machinist liked this post
  27. #19
    Apr 2007
    Dublin Texas
    2,591
    1408
    917
    The tank hasn't had fuel it it for 30 years that I know of. No odor, but I will have a big mesquite fire in it to purge it. I've done it before. I'm going to build a trailer that I can stand it vertical like it was dropped, with the smoke comming out the tail. I'll build an insulated fire box for the nose. I wanted it insulated because I'm a fan of ww2 bomber nose art and was thinking about putting some on it. Just didn't want it to burn off. Already started the SolidWorks files.
    Yeah, I've got too much time on my hands
    have fun
    i_r_
  28. #20
    Oct 2005
    14,552
    have fun
    i_r_
    Gonna label it "Fat Man" ?
    Fat Man - Wikipedia
    Or maybe "Fat Bastard"
    Fat Bastard (character) - Wikipedia
  29. Likes i_r_machinist, jmead, Larry Dickman liked this post
