OT - Insulating a quonset-hut style building - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21
    Apr 2007
    A little north of Houston, TX
    798
    22
    How thick is it and what did it cost?
    How flammable is that stuff- for 4th of july when all the fireworks land on the roof?
  2. #22
    Mar 2010
    Arlington, TX
    257
    11
    30
    2 inches thick for 10,800. The full 2 inches haven't been sprayed yet. It will be topcoated with white elastomeric paint. MSDS shows flammability as a slight risk. It will burn if exposed to flame long enough, not any more flammable than asphalt shingles.
  3. #23
    Jan 2005
    Victoria, Texas, USA
    3,843
    1900
    925
    Looks almost like 2" of snow in summer!!!!
    Ken
  4. #24
    Mar 2010
    Arlington, TX
    257
    11
    30
    yeah yellow snow
  5. #25
    Apr 2007
    798
    22
    I wonder what the contractors profit level is on these foam jobs.
  6. #26
    Jun 2004
    525
    8
    Default Profit Level?
    These foam guys really do work for their money. The guy that did my shop had serious equipment - 3" in one pass. Big truck, giant dual airless setup, giant compressor, all self contained for those no power at the site jobs. That's a lot of gear, plus 2 helpers.
    Also, while the MSDS looks pretty friendly on the cured foam, while its being sprayed its a serious health and explosion hazard (unless maybe the newer water based eliminates these risks?).
    So: Big truck, Big compressor, dual airless, 2 helpers, 55 gallon barrels of Part A and Part B.
    In some cases multiple coats, then mandatory to paint over, as UV deteriorates it from the outside.
    I had mine put on the inside - ~ 10 years on, no delam or 'foam snow'.
  7. #27
    Mar 2005
    It's been 9 years how is the exterior insulation holding up?
  8. Likes JoeE. liked this post
  9. #28
    Apr 2007
    mays landing NJ
    484
    437
    130
    I would install 2" blue foam panels inside. I have seen this done but never installed foam like that.
    Installers placed a 2" x 1/16" thick square metal plate with a 3" pin sticking out of the center. Panels are pushed onto the pins and another thin plate with a center hole is placed over the pin. This acts as a washer. Do not know what these pins are called and the dimensions I gave are from what I recall 20 + years ago.
    I recall that 2 installers insulated large areas with little or no problems.
    mike
  10. #29
    Apr 2004
    Modesto, CA USA
    6,592
    1074
    I just had a new asphalt shingle roof put on my house in California. In Califorina the shingles must meet "cool Roof" specs. This means they have to reflect some heat so no black shingles allowed. Some are pretty black but they still reflect heat fairly well.
    Bil lD
  11. #30
    Apr 2004
    Modesto, CA USA
    6,592
    1074
    A bit off topic but when did they stop tinting sidewalks with lamp black. In the 1950's sidewalks and driveways have a slight gray color. New concrete is just stark white and does not blend even after years of dirt. I suppose at the same time they stopped color coat stucco and switched to more expensive and much less durable paint instead.
    Bill D
