iPhone 6s.... if battery removed and the batteries little circuit board also removed from the battery... and 3.8 VDC applied via lab DC power suppy to this board should the iPhone power up ok even with the screen not closed ? (i.e. all ribbon cables connected but the two halves are separated). Suspect the answer is "yes" and I now need ultrasonic cleaning in 99% isopropyl alcohol. (and even that might not work in reality) But still I wonder...
Next will come questions as to why I want to know this.... and the answer has to do with overturning in a kayak with a phone in pocket...then "why did you have a phone in your pocket during such a risky activity ?" and then "why not put it in baggie at least" and then on and on.....
