mfisher
Hot Rolled
- Oct 24, 2006
- Annapolis, Maryland
I am looking at a boat that has some toe rail damage, from catching on pilings. I haven't been able to find a match after searching the web for a while. Boat is a 1993 PDQ sailing catamaran.
Bolt spacing is at 4", and I believe that are 1/4" (forgot to measure). I would like to stay with the same pattern if possible, since just the two main outer runs are damaged, there are several more shorter pieces between the hulls that are ok, and I would prefer not to switch, but that wouldn't be the end of the world if I had to.
Photos below. Any thoughts? Crest Aluminum didn't have anything, nor did TACO. The main lengths are 32'8", which could be a problem to ship, but I am thinking about adding a cleat in the center anyway, so shorter runs (20ft or so) would work.
Any help appreciated.
