anchorman
Titanium
- Dec 19, 2005
- Opelika, AL
I have asked others about this, but I can't seem to get a straight answer from anyone who really knows what they are talking about. just a bunch of hoodoo and conjecture.
I have a stock 1983 honda xl600r that pings more often than I would like when under load at mid to high engine rpms. like accelerating from under 45 mph in 5th gear. I know with most bikes you could chalk this up to bad driving technique, but with a big thumper, this shouldn't be a problem from my previous experience. I have ridden KLR 600's from the same time period, and they never gave trouble when doing this. I also have a stock 1985 honda XL350R that does not manifest this problem, even in 6th gear from 35-40 mph.
I read somewhere a while back on the forum that maybe the gasoline composition has changed and does not atomize in carbs as well as it used to? I cleaned the carbs and jets meticulously and put on new gaskets, etc. The jets are of the original factory size in the proper places (dual carb model), so I am guessing this should not be a problem. air filter is new and properly oiled, and all the rubber is still soft on the intake and airbox, and seems to seal up well. is there any way to check for leaks along there?
I want to believe that it is just bad driving technique that is making it ping, but like I mentioned, I have driven other bikes poorly in the past and it didn't affect them like that...
suggestions that I could try out? thanks,
jon
jon
