SteveF
Titanium
- Jul 4, 2004
- central NC
So, the Generac 5500XL (09778-3) whose carb I mentioned in the bad gas thread is back together with its shiny clean carb. Set the choke and it started on the third pull like new. Turned off the choke and the motor went to a pretty high RPM but ran fine. Checked the output voltage and measured 145/290, 12.6 on the DC output. Crap. By manually moving the throttle lever I can get the RPMs down and the voltage to around 124, DC output at 10.6.
The manual says to adjust the idle but not let the frequency go below 45 hz. Well, I don't have a way to measure that.
Checked on the Internet and YouTube but haven't found anything that helps.
I always take photos of anything I'm about to take apart so am pretty sure it is back together correctly. One bit of concern is a spring on the throttle rod and just connects to the holes that hold each end of the throttle rod. Seems odd that a manufacturer would put on a spring that seems to serve no purpose. Pictures show it that way before disassembly but maybe I worked on it two or three years ago and moved the spring. It seems like I would fix the problem if connected differently but the only place it could be connected to otherwise, it isn't long enough to reach.
Anyone know anything about portable generators and what I might be able to check? What I'm calling the throttle rod is the rod on the upper left.
Thanks.
Steve
Thanks.
Steve
