OT- Need lock for home sliding door ... possibilities ?
Results 1 to 14 of 14
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,281
    2785
    5589
    Default OT- Need lock for home sliding door ... possibilities ?
    For door with hardware like below....does there exist a lock to fit where the "grip" plate is now ? (i.e. no drilling for separate lock...realizing I'll have to install a catch for the lock in the door frame of course)
    Sep 2015
    Ohio
    1,062
    634
    1025
    Pocket door lock? Might have to search a bit to find the right size.
    Nov 2014
    Florida
    3,427
    1474
    1618
    We had something like that when I lived up north. It was a recessed 'panel' with a sliding lever for the lock mechanism (unless you are talking a keyed lock )...
    If you just want a way to lock the door from the inside, they make bars that basically jam between edge of door and frame.
    https://www.amazon.com/slp/security-...4g62dqeu8gkyqn
    Or a 1" or so wooden 'dowel' from Lowes cut to length.
  4. Likes DrHook liked this post
    May 2017
    Massachusetts
    269
    249
    130
    Anderson might have an appropriate mechanism. Check out their exterior sliding doors.
    Nov 2013
    Eastern Massachusetts, USA
    4,089
    4406
    4295
    If there is a good locksmith in your area you might stop in and ask them. Many times they are aware of hardware that may not be common, especially the older stuff. Even if they don't have anything on hand they may provide the exact name, which helps when looking.
    May 2017
    Massachusetts
    269
    249
    130
    Feb 2014
    Sunny South West Florida, USA
    2,680
    10284
    3108
    Several come up on google as well: pocket door lock - Google Search
  9. #8
    Mar 2009
    Brunswick Oh USA
    4,492
    4964
    2676
    Quote Originally Posted by TeachMePlease View Post
    Right. As his pic indicates, it's a pocket door.
  10. Likes Milacron liked this post
  11. #9
    Dec 2000
    51,281
    2785
    5589
    Locking from inside would be easy...I want to lock from outside.... Reason= contractor workers roaming about doing interior reno for a week or more...would like to lock home office behind sliding door. (which doubles as the laundry room, hence the lack of proper door with proper lock.. )
  12. #10
    Mar 2010
    Davidson NC USA
    1,420
    511
    808
    The down-side to the handy sliding door is the lower track. A small crowbar will lift the door off the track, so that it can be pulled outwards and defeated.
  13. #11
    Nov 2013
    4,089
    4406
    4295
    Following the link that TeachMePlease provided I found this writeup. It does mention that notch dimensions vary somewhat by manufacturer so it may take some digging.
    Standard Notched Style Pocket Door Hardware
    However, since that seems to be a painted door it would be no big deal to either enlarge the notch or glue in filler strips, as needed. That would be worth doing if your current pull has uncommon dimensions.
    Quote Originally Posted by sealark37 View Post
    That can be solved by screwing in a small block at top. In order to lift the door off the track it is then necessary to open the door somewhat and unscrew the block.
  14. #12
    Mar 2009
    Brunswick Oh USA
    4,492
    4964
    2676
    I've never seen a pocket door with a lower track.
  15. Likes Milacron liked this post
  16. #13
    Nov 2014
    Florida
    3,427
    1474
    1618
    DERP!! I saw sliding door and immediately thought "patio door"...
    If it is an emergency I would just screw on latch and use a padlock. Patch up/paint holes when done...
  17. #14
    Virginia
    26,062
    7561
    8223
    THIS. It's only temporary. It can only keep "honest" people out, anyway.
    I'd just use a sash-window keylock, but at the TOP of the door.
    https://www.homedepot.com/p/Prime-Li...9863/100209983
    The screw holes will be smaller and easier to fill when you remove it!
    Even easier if you do NOT remove it, just adapt to the door not opening quite as wide.
