OT: need Omniturn 12 foot long bar feder
Results 1 to 8 of 8
    Jan 2005
    Los Angeles
    445
    19
    119
    Default OT: need Omniturn 12 foot long bar feder
    I tried this in the Machinery forum and the Tooling forum without results.
    I need a Omniturn pneumatic bar feeder for 12 foot bars.
    Sorry if I am in the wrong forum.
    Lost
    Nov 2013
    Utah
    2,581
    711
    1377
    I built one with 1.75" pipe and an elongated "plunger" thingy. Just put it all together, about 13' long, on some stands. Built Plunger big enough that it would react to compressed air from the back end, but loose fitting over all (Delrin® IIRC). Put a cap on the front end of the pipe with a hole for stock, smaller than the OD of the Plunger, and a lever valve for the air, Rock-N-Roll.
    The Plunger had a Concave face, then tapered off the back to a point, OAL about 8". Might have had an O-Ring on the OD???
    R
  3. Likes Limy Sami liked this post
    Oct 2005
    10,286
    17357
    5369
    Mar 2014
    Nebraska
    312
    42
    205
    Any reason against hydraulic? Other than the fact they can be a bit messy at times the LNS Hydrobars are pretty much bulletproof and really simply designed
    Oct 2010
    Dewees Texas
    1,830
    23
    453
    Just in case you change you mind and decide to do weight driven look at the #4 post. The bar feeder is space saving and could easily be made 12 foot instead of 6. The size of the support bars as well as spacing is based on the weight driven bar feeder on our A42 Traub screw machine.
    http://www.practicalmachinist.com/vb...trofit-279639/
    Jan 2005
    Los Angeles
    445
    19
    119
    Default OR a 6 foot bar feed
    Thank you for your suggestions. I am still looking.
    A 6 foot bar feed would work.
    Lost
    Jan 2007
    Norfolk, UK
    17,125
    12766
    12316
    R
    BTDT and they work a treat, - I used a length of aluminium scaffold tube (about the same size as your 1 1/2'' sch 40 pipe) .take a tip - don't over think or engineer it keep things on the loose side - KISS is the watchword,
  9. Likes litlerob1 liked this post
  10. #8
    Sep 2005
    Oakland, CA
    2,071
    104
    501
    A leather pump seal on the piston works great- McMaster-Carr has them. I have some new 110v air solenoids. If you want one, drop me a PM and you can have one for the shipping cost.
  11. Likes Limy Sami liked this post
