Weirsdale George
Stainless
- May 17, 2003
- Weirsdale, FL
I tried to fill a tub in a little used bathroom in my house only to find out that the water is barely coming out the faucet (maybe one gallon a minute). The valve is a single handled Delta (I think) which when in the 6:00 position is off, rotates 270 degrees CCW through cold to hot. In the adjacent sink, the hot and cold water both flow normally, so it is not like I am missing one or the other. The water coming out of the tub faucet is warm, but not hot, so there is some mixing in the valve. It appears that both hot and cold water are coming to the valve, but somehow, the valve is restricting the flow of both. What do I do to correct this problem. (FWIW, the house is ten years old.) Thanks.
