MT6
- Dec 25, 2004
- Northern Colorado
I'm trying to source a 1.75" OD seal for a brake master cylinder from a road grader. I can order a rebuild kit for around $300 or a new master cylinder for $700. I trying to fix this as a favor for a neighbor. The bore of the cylinder is pitted which wore out the seal that's in there now. I plan to bore out the cylinder and sleeve it with piece of 1.75" ID stainless air cylinder tubing. Already bought a cylinder and the ID is spot on.
I contacted MICO and was connected to an engineer. He was very help full but the cylinders are now assembled in Mexico and he has no access to any parts. Contacted a brake supplier in Florida and he was less than helpful.
The seal that's in there now was obviously modified as the ID of it was nibbled out to fit around the piston. It worked until it was worn by the pitting.
Ideally the seal would be 1.75" OD 1.35 ID with the lip about .45 high. 1.75" is close to 44.5 mm if that helps. My google foo has been exhausted trying to find anything even close. It does need to be rated for DOT3 brake fluid.
Yes I'm aware of the liability but I'm trying to get him some brakes and his budget is slim.
MT6
MT6
