Kyle Smith
Stainless
- Apr 25, 2008
- Helmer, Indiana, USA
I installed a new house water filtering system in March of this year. The system worked fine until July when both gauges of the first filter assembly developed a leak. I initially thought the gauges had failed and just bypassed that whole filter assembly. A few days later both gauges on the second filter assembly began to leak and then I bypassed the second filter assembly. I used cheap gauges, MCM part #4089K61, since this is just a 50psi potable water application. Yesterday I installed one better quality gauge, MCM part # 4003K11, as a test drive and it was clear that the pipe bushing was leaking and not the gauge. After inspection a crack was visible on all four bushings.
The system typically operates at ~ 45psi, but I have seen the gauges bottom out a few times at greater than 60psi. I haven't looked into this issue and was never aware of it since I didn't pay much attention to the gauge on the pressure tank. The pressure tank gauge may not be functional, I got tired of this project and moved on, but I need to replace that gauge as well. I cannot remember how it compared to the filter gauges when I saw them bottomed out. This is why I suspected the gauges in the first place, maybe I had damaged them with pressure, this seemed unlikely as I doubt it could have been much more than 60psi.
The day the first set of bushings failed I was filling a kid swimming pool with 1000 gallons. I filled it off and on throughout a 6 hour period. The system got fairly cold during this, whatever well water temp is in northeast Indiana, enough to make a good deal of condensation on all the pipes.
The pictures of the two fittings show the cracks on each. I machined a flat on the one and cleaned him up to highlight the crack. All four bushings cracked in the same manner, not all exactly in the same location relative to the hex. The bushings are MCM part# 4429K422. I disassembled these fittings with two 6" adjustable wrenches, I didn't go after these like a 200lb gorilla.
My only guess is a defect in the material, although this seems unlikely, but maybe they had a large enough run of poor material, that I could get four that all had the issue. This type of failure is the worst case if this was a second floor bathroom as the fittings did not leak for four months.
