rmcphearson
Hot Rolled
- Jan 12, 2008
- Rochester, NY
I got stuck at the shop last night doing brakes with no help and used the old mason jar method of brake bleeding which worked very well. Here is a quote by GregSY from an old thread that supports my desire to make a "professional" version:
"A simple jar - it can be a pickle jar or a plastic Slurpee cup - works better. Run a piece of hose from the bleeder valve on the caliper to the jar and submerge it in brake fluid. Wehn you push the brake pedal down, air will go into the fluid in the jar. When you let up the pedal, it will pull fluid back in. Do this a bit and you will have no more air in the lines.
All the pressure and vacuum methods work a little faster but they are all inclined to intoridue new air into the system. The method above gives the hardest pedal feel...no air." -GregSY
I bought a Mity-Vac hand pump type vacuum bleeder last year, tried it one time and didn't like it. Maybe it was the cheap opaque urine sample cup that turned me off. I don't remember. I just didn't like the fucking thing. I remember that much.
Anyway, I'd like some help coming up with the ultimate old school glass jar kit worthy of being passed down one day. I would like:
1) a couple different size bulk head fittings/nipples on the lid with tubes that extend down to just above the bottom. Are there bulk head fittings available?
2) a bi-directional flow indicator so I can see that fluid is moving in both directions. Is there such a thing?
3) whatever else I should include in the kit (I'm not a very experienced brake job guy). Any suggestions?
Roland
Roland
