OT plumbing
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: OT plumbing
    Dec 2008
    Vt USA
    9,539
    1698
    3497
    Default OT plumbing
    I'm wondering if the "good old days" of pipe dope and teflon tape should be put aside.
    I just put in an out door shower (just in time for 90 degree days)
    But the shower set up has two risers of smooth chrome plated pipe.
    Not a wrenching flat to be found. What's a guy to do? put pipe wrench bites in polished steel? Three vise grips with padded jaws just to hold the polished riser while snugging the fitting.
    I'm thinking "gorilla glue " is the new pipe thread sealer.
  2. Likes johansen, D.Minnich liked this post
  3. #2
    Aug 2014
    bainbridge island
    1,447
    317
    359
    i don't know the percentage but it seems like well over half of plumbing fittings are rubber seals in a house these days.
    straight chrome plated pipe on a shower head sounds to me like it threads onto a rubber washer. probably says hand tighten plus 1/4 turn.
    Feb 2006
    Indiana
    14,043
    817
    4788
    Strap wrenches with rubber coated Kevlar or similar material straps are made for chrome plated pipe. I have had my first one for about fifty years, so they are not a new idea.
    Larry
  5. Likes paulz, rklopp, sfriedberg, BT Fabrication liked this post
  6. #4
    Dec 2008
    Vt USA
    9,539
    1698
    3497
    Quote Originally Posted by L Vanice View Post
    Larry
    Have you tried a strap wrench on a 1 inch dia. chrome pipe lately? I have. Ain't for shit! too small. the strap has too little wrap.
    But hey. show me. I'm game. hmm rubber coated Kevlar... now there is something everyone should have in their tool box.
  7. #5
    Dec 2008
    Vt USA
    9,539
    1698
    3497
    Quote Originally Posted by johansen View Post
    NPT has no rubber parts that I know of......
  8. #6
    Mar 2009
    Eureka, CA
    4,447
    1060
    1810
    Doesn't the smooth, chrome steel pipe attach to some fitting with flats...like a shower head? It can't just be a smooth chrome pipe attached to nothing!!
    Stuart
  9. #7
    Dec 2012
    AUSTRALIA
    4,811
    28
    1738
    Think Permalee pipe wrenches...and you cant get any more old school than Permalee
  10. #8
    Nov 2003
    6,060
    217
    2094
    Strap wrenches come in many sizes. I even made one for tightening electronic connectors of about 3/4" OD. It works swell. The strap has about 270 degrees of wrap and you will strip the threads before it slips.
    As for Gorilla Glue for sealing pipe, FORGET IT unless you want a shower. They still sell good, old pipe dope and it still works just fine. I am told it is still preferred to teflon tape but I have used a lot of teflon tape on air systems. Teflon tape comes apart easier when repairs are needed.
    Quote Originally Posted by CalG View Post
  11. #9
    Jan 2007
    wales.uk
    1,868
    421
    439
    Wrap with self amalgamation tape and grip is my solution, kind of works, even blow torches and solder are disappearing for crimped fittings ( crimping tools around £800!) soon to be made law the rumour mill says, mainly to stop diy plumbing
    Mark
  12. #10
    Aug 2019
    116
    117
    Quote Originally Posted by boslab View Post
    Mark
    Crimp ring PEX is very common here and tooling is ~$100 US. I've been using it a while and haven't had any issues with it. It's also nice when you need to change things as the valves and other metal fittings are easily reused, only the very cheap crimp ring and an inch of the PEX tubing is wasted. I'm getting ready to build a new hose and I'll be using PEX throughout, home-run to nice pre-fab manifolds. We did that on a friends house build near 10 years ago and still no issues.
  13. Likes bryan_machine liked this post
  14. #11
    Nov 2006
    Bowling Green, Ohio
    388
    158
    Take some small rope or twine about 4 feet long - maybe longer, tie the ends together, wrap one end of the loop around the pipe while threading the other end through the loop. Wrap the rest of the twine around the pipe to tighten the wraps around the pipe. When you have it all wrapped around the pipe, place a stick through the end of the loop. The stick becomes the handle of a pipe wrench that will tighten around the pipe but will not damage the surface of the pipe. The length of the twine is determined by the diameter of the pipe.
    Bob
    WB8NQW
  15. Likes magneticanomaly, SIP6A liked this post
  16. #12
    Feb 2006
    Indiana
    14,043
    817
    4788
    Mark
    I had a new water heater installed by pros in 2019 and saw crimped copper fittings for the first time. They used a very expensive battery-powered Milwaukee crimper. So I saw an opportunity to add another tool to my collection. I bought a Chinese-made hydraulic hand crimper from Amazon and some fittings to try it out. It works fine and only cost $102. The one I bought is no longer available, but they have similar ones for not much more money.
    VOTOER Hydraulic Copper Tube Fittings Crimper Crimping Pressing Tool w/ 1/2", 3/4" and 1" Jaws - - Amazon.com
    I would not use crimped fittings visible in a finished area like a bathroom, but they are OK in a utility room for a water heater.
    I have had a couple of pinhole leaks in my copper water lines over the years. I have found the best repair is a slip-on repair coupling. It is more expensive than a solder coupling, but no tool beyond a tubing cutter is needed and they are quick to install.
    1 PIECE XFITTING 3/4" PUSH FIT SLIP/REPAIR COUPLINGS 4-1/4 INCH LONG CERTIFIED TO NSF ANSI61 - FULL PORT, LEAD FREE BRASS - - Amazon.com
    Larry
  17. #13
    Dec 2008
    Vt USA
    9,539
    1698
    3497
    Quote Originally Posted by atomarc View Post
    Stuart
    Yes, it attaches to a chrome plated brass compression flange. also featureless as pertains to rotation.
    Even the reviews on the assembly indicated it was very difficult to seal.. I should have taken that as a sign ;-)
  18. #14
    Dec 2008
    Vt USA
    9,539
    1698
    3497
    Quote Originally Posted by EPAIII View Post
    I started with PTFE tape, switched to Rector seal. It took way more tightening than it should have.
  19. #15
    Oct 2013
    New Jersey
    1,343
    7
    1157
    I find that most people have trouble with a strap wrench actually are using them the wrong way. Take a look at the instructions for a Ridgid strap wrench and you’ll see what I mean.
  20. #16
    Feb 2019
    Iowa
    56
    13
    I would think a strap wrench wrapped a few times would get it tight enough not to leak with teflon tape. I have a few times used a properly sized split collar to grab the pipe just good enough not to damage it and put a pipe wrench on the split collar. I try to put the pipe wrench on as to squeeze the collar shut so it won't try to slip too bad. with all the surface of a split collar if it does slip usually there's not much of a mark.
  21. #17
    Dec 2008
    Vt USA
    9,539
    1698
    3497
    Quote Originally Posted by ferrretcatcher View Post
    Yup
    I used three vise grip pliers packed with 1 inch webbing. That worked for one end, but the flange end is only wide enough for a single wrench. I might just say screw it and put the pipe wrench to it. Sometimes water leaks stop themselves by magic! ;-)
    Then too, it's an outdoor shower, it will all come off the wall with the first freeze warning in October. That shower sure was nice this evening before supper.... ;-)
  22. #18
    Sep 2010
    Oklahoma City, OK
    5,643
    1093
    2469
    Ran into this just this week. I took a work glove, the kind with rubber in the palm, wrapped it around the brass and then gripped that with knipex alligators. Got it tight with no fuss and no scratches.
    Sent via CNC 88HS
  23. #19
    May 2011
    New Jersey
    747
    19
    261
    To tighten clean pipe, use a piece of leather between the jaws of the pipe wrench or channel locks. To have more grip, put a piece of silicone sheet between the leather and the pipe. You will destroy the leather the tighter you get, but it will have no marks
  24. #20
    Mar 2009
    Eureka, CA
    4,447
    1060
    1810
    I don't quite understand where you would need to join these shiny chrome pipes that there wasn't an elbow or a tee or a whatever that would give you a spot to grab and tighten. Don't all plumbing pipes have some fitting on their ends?
    Stuart
