moonlight machine
- Nov 19, 2007
- marysville ohio
I replaced the faucet and sprayer on the kitchen sink on saturday. The old one was dripping and was some odd brand that no parts were available for. What should have taken an hour or so burned up a good share of the day. I have one of those wrenches for reaching up behind the sink to un do the nuts on the supply pipes, no problem. But those f ing plastic nuts that hold the faucet to the sink had somehow welded themselves in place. I got 1 to turn a bit then it was done. went out to the shop found a bit of tube the correct size and milled 4 slots in the end to fit the 4 bits that stick out of the nut to use as a way to grip the nut. The tool fit the nut perfect, I tried to turn the nut and the 4 bits sticking out sheared off instantly. Sh!t!!! The sink is on an island right in front of the refrigerator. It is too close. The edge of the cabinet I was laying on had about a .020 radius on it. The drain pipes and traps and disposer were to low to get your head under to get a good look at what you are doing. Next I tried to split the nuts with a hammer and chisel, can't see what I am doing, can't get a swing on the hammer, The tool broke the nut instantly but no f ing way was that nut was going to split! Back out to the shop, got the appropriate size hole saw, cut it in half and added a piece of tube to it making it deeper. I put it in my 18v milwaukee drill and reached up there and hole sawed the center out of those bastard nuts! Ok the old one is out! The new one is dead easy to install, bolts right in in about 10 minutes using the original supply pipes, they are exactly the correct length! OK good it all works, no leaks. Problem! It flows about half as fast as the original one, even with the aerator off...I can piss harder than this thing flows....SWIMBO hates it! WTF! Is there some sort of gov. mandated water saving restrictor built in this thing? It is a Moen brand, made in china of course. I hate working on the house!
