I'm looking for a PCB layout and reverse engineering service that can take a sample board and provide Gerber files ready for manufacturing. I've done some searching and there are many companies out there who advertise this service but a recommendation from a PM member with experience in this area would be excellent. I also searched PM archives and there are members who have done similar projects but I'm not sure they are active anymore.
The full explanation is we have a product line that involves replacing 30-40 year old PCBs, dimensions approx 6" x 15". They only have terminal connectors, no other components. So to my mind the electrical engineering is fairly simple, however the boards use nonstandard terminal connectors and are made up of 5 thin layers stacked on a plastic(?) panel. I'm not sure of the correct terminology for this type of PCB composition but someone used to working on newer electronics may be unfamiliar with it. We need to replicate multiple designs of this type in modern, multilayer FR4 boards. In the past we have had them remade but the company we worked with is no longer around and unfortunately my predecessor was not tech-savvy enough to request layout files.
Any recommendation would be much appreciated!
