OT Removing the rear wheel from a John Deere lawn tractor. - Page 7
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 121 to 140 of 144
  1. #121
    Nov 2008
    Madera county california usa
    2,532
    21
    639
    Drilling a hole...odd idea...
    2 options here.
    From end or side.
    You can drill and tap a hole for a grease zerk in the end or side of axle.
    You can possibly weld a pre-tapped hole on side and drill hole through wheel.
    This allows grease to be shot into the area and possibly separate it.
    Your best bet is to break the bead and a pneumatic chisel on May do the trick.
  2. #122
    Aug 2012
    California, Central Coast
    4,384
    2275
    1748
    Haha...I imagine the converation between Charles and Jack comparing slime to tireject to go something like this:
    Charles, No Jack, I like the slime better since it is heavier, when I pick up the tire I want to know it is in my hand.
    To which Jack responds, I like the tireject for its light weight, that way I can pick up the tire with a beach babe perched on top of it.
  3. #123
    May 2002
    South Central PA
    13,886
    2432
    3675
    Quote Originally Posted by Tony Quiring View Post
    2 options here.
    From end or side.
    (snip)
    Tony, you are attempting to be sensible here. I meant poke holes in the sidewall of the tire or in the wheel and fill it with latex caulk. A half dozen 3/8 holes should do it, would take maybe 3-4 tubes of caulk and 30 minutes, Wheel would no longer need to be removed from axle and tire would no longer go flat, A dollar store version of foam fill.
    WWRGD? (What would Red Green do?)
  4. #124
    Dec 2007
    Central Ohio USA
    3,952
    92
    1774
    Quote Originally Posted by moonlight machine View Post
    Great idea, you will arrange it then? Wait, LaLanne is in Forest lawn pushing up daisies.
    Dead, and still doing push ups. What a guy!
  5. Likes GregSY liked this post
  6. #125
    Jan 2005
    Houston
    6,243
    787
    3005
    We see often news articles on the last WWI veteran or the last steamboat captain or the last whatever. I have to wonder if the very last one-piece-jumpsuit-with-the-little brass-T-clasp-belt-wearing old man has passed?
  7. #126
    Nov 2007
    marysville ohio
    9,862
    2819
    6574
    Quote Originally Posted by Chip Chester View Post
    He had a heart attack while he was exercising, that's why I don't
    exercise.
  8. #127
    Nov 2007
    marysville ohio
    9,862
    2819
    6574
    Well, I mowed most of the day sunday with no c clip holding the wheel on. Soaked with Kroil, I aired it up and sprayed kroil every 2 hours It is still stuck.
  9. #128
    Nov 2013
    Eastern Massachusetts, USA
    5,470
    5197
    5238
    At this point either replace the tire in place (if possible) or grind. torch, chisel the hub as needed to get it off. I don't think normal (as in part saving) methods are likely to work. I'd probably use my right angle pneumatic die grinder with a 2" grinding disk as it gets in almost anywhere.
  10. #129
    Aug 2012
    4,384
    2275
    1748
    Put the sealant of choice in it and never worry again. The rest of the tractor will probably die before the tires wear out.
    Super easy to do, remove valve stem, squirt in sealant, re-install valve stem, air up tire, go mow to spread the sealant, maybe top up with air if it took a while to seal completely.
  11. #130
    Nov 2007
    marysville ohio
    9,862
    2819
    6574
    Quote Originally Posted by Rob F. View Post
    One of the fronts that I put tubes in had sealer in it. Leaked anyway, what a disgusting mess to clean up when I put the tube in.
  12. #131
    May 2008
    Florida
    273
    30
    142
    I used some of this to seal the tubeless tires on the Kubota.
    Not sure which one I selected, might have been the “bulletproof”, but 10 years on it is still working.
    seaalant — Gempler's
  13. #132
    May 2002
    South Central PA
    13,886
    2432
    3675
    I'm tellin' yall, it's time to go Red Green onit.
    Relevant to nothing -
  14. Likes shapeaholic liked this post
  15. #133
    Jan 2007
    Florida
    1,184
    150
    429
    about a year later both of mine with the two part foam are working just dandy. (i can get my wheels off i just didn't want to buy new tires/wheels for 200)
  16. #134
    Aug 2012
    4,384
    2275
    1748
    That is a bad thing about the slime& its copies. I will get the tireject next time I need to do a tire, the website says it is water clean up.
  17. #135
    May 2002
    South Central PA
    13,886
    2432
    3675
    Quote Originally Posted by cg285 View Post
    this is what i used on my mower steering tires. drilled two holes in the center of the tread and filled em up
    Froth-PAK 12 (1.75 PCF) Sealant - Froth Pack Foam - Amazon.com
    I missed this the first time through. How firm does it get? Is overfilling a concern?
  18. #136
    Jun 2001
    lancaster,ohio.43130
    935
    18
    141
    Hey Moonlight, I see Your from Central Ohio, can You get to Craiglist or FaceBook Market space. Plenty of tires and rims there. Would not have to wait on shipping. What size is the tire, might have one laying around? I don't know if I am allowed to mention those names here. I am in Lancaster. Delete if offended.
  19. #137
    Jan 2007
    Florida
    1,184
    150
    429
    Quote Originally Posted by Mud View Post
    drill two holes 180 apart, any excess gets cut off
  20. #138
    Aug 2005
    Tucson AZ
    6,466
    9957
    3039
    Has it not occurred to you that the reason caulk compound does not set up in the tube would apply in a tire casing? Retard idea.
  21. #139
    Jul 2006
    Hillsboro, New Hampshire
    9,222
    2187
    6382
    Ultimate solution - rotary gas coupling, compressed nitrogen tank and regulator, and a few brackets and air lines to connect the coupling to the tire Schrader valve. Unless it's a tiny N tank, mow as much as you want.
    Substitute portable compressor if you've got an alternator or big-ass battery on the mower.
  22. #140
    Nov 2013
    5,470
    5197
    5238
    Quote Originally Posted by fish123 View Post
    Yeah, Gemplers is a supplier to agricultural workers and the products they sell are far superior to Slime and other common retail stuff.
