dkmc
- Jan 13, 2002
Mower deck spindles....2 of the 3 have ball bearings with different seal types.
One has a single sided rubber seal on the top, shielded bearing on the bottom.
Other 2 have shielded bearings both top and bottom.
I'd like the replacements to have rubber seal equipped bearings both top and bottom,
single sided because there is a grease fitting on the spindle housing.....
So 2 questions:
1.
Would rubber seals be able to handle the RPM these bearings operate at?
Looking at engine RPM, deck gearbox, pulley sizes, my guess is, the blade spindles are in the
3400 - 4000 RPM range. I know they can overheat at higher than max design speeds.
2.Are rubber sealed bearings externally re-greasable?
IOW, if I pump grease in the spindle thru the grease fitting, will it just ooze past the seal,
or is the seal so stiff it might just hold the pressure till it blows out?
Remember, these will have the rubber seal only on the outside, and the inside will be open in
the housing.
So 2 questions:
1.
the housing.
