I'd like to add a heat lamp in my pump house, it's a 120 volt 250 watt heat lamp, the 1 hp pump is wired for 240 volts going to it from a 30-amp double pole breaker, 2-120 volt white wires and a black ground wire attached to the pump frame but the pump is not grounded just attached to a 2" PVC outer well pipe? So is there a good way to hook a 120 volt light up to this without running another 120 volt circuit to the pump? I've seen it done a lot but I know just enough about wiring to know I need advice on this. And yeah I could hire an electrician but if it's very simple I think I can do it. Thanks
