Problem Radon Elimination NOT Mitigation
Typical radon mitigation, radon removal and radon reduction systems are merely an attempt to redirect radon with no way to STOP radon gas from entering through the foundation. We Keep The Radon Out! Sani-Tred Basement Radon System guarantees to reduce basement radon gas to below safe radon levels. Due to Sani-Treds’ Basement Radon Proofing products unique physical properties, our Basement Radon Proofing System has the extraordinary ability to permanently radon proof and waterproof your basement for the life of the structure with a life time warranty. Sani-Tred products are do-it-yourself products and can be applied by anyone! Proper and thorough basement waterproofing is critical before basement remodeling or basement finishing is completed to eliminate the possibility of a damp basement, wet basement, basement mold and to keep out radon. A perfectly dry basement is an added bonus to our radon system. Sani-Tred products permanently solve most all basement repair needs, repairs and seals all basement joints, basement cracks, seals all basement leaks while sealing out radon gas at the same time. Sani-Treds’ Basement Radon System permanently protects all of the basements’ contents such as basement framing, basement insulation, finished basement flooring materials among all other basement finishing materials. The basement radeon proofing industry is extremely competitive because the market is literally flooded with radon related products and basement radon proofing systems that DO NOT WORK.
