WizardOfBoz
- Sep 30, 2006
- SE PA, Philly
SWMBO is a Physical Therapist (a Physiotherapist to those of you living in the UK and the far-flung parts of former empire). The cold packs that they use are fairly costly ($15-20) and break (a couple bags a week). So I get
"Can you figure out a way to fix these?"
"Umm, ok, but why don't you find another supplier?"
"We switched to this supplier because the previous supplier's bags were worse"
"Okey doke. I need to think about this - I think these are ultrasonically welded"
"Can't you put a vinyl patch on it? Duct tape doesn't work."
"Umm, yeah, duct tape isn't gonna get you a seal, and since the break is a split in the seam, no patch will work".
"Can't you figure out how to fix these? P-l-e-a-s-e...? You can fix anything!"
"Okay, I need to think a bit about it".
The penetrating minds of the ladies and gentlemen of this forum will no doubt get the idea. So,
1. Am I right? Are vinyl seams typically U/S welded?
2. Is there a glue I could use? I was thinking of some sort of vinyl compound dissolved in a solvent, applied to the seam using a syringe (there is the problem of having a syringe full of lethal plastic/solvent in a hospital, yes...)
3. Or is U/S welding the best option. I have to think that a U/S welding apparatus is expensive.
4. What about a metal crimp?
4. Other ideas?
Given that the expensive bags are not durable, I do plan to suggest that my wife's hospital buy the absolutely cheapest product and assume it will be a use-once product. Or figure out what the gel packs contain, and make 2-300 of their own cold packs each week using zip-loc bags. Would cost about 50 cents/bag I think.
This is clearly a case where the market asks for cheap, Chinese cheap. And the Chinese are producing what is asked for. I think that the vendor may realize that his bags are breaking and that this is good for business, too, so he has no incentive to make/supply a good product.
Any help in making my sweetie a bit more relaxed about cold packs?
Thx,
Jim
4. Other ideas?
Thx,
Jim
