oliverdude
Hot Rolled
- Feb 25, 2007
- Osage City
A few years ago I bought some high output 8ft. fluorescent lights for the shop. They look just like a normal fluorescent light, but they use a little different bulb and ballast. They start GREAT in cold weather, but as it warms up and the humidity rises, they don't start as good, if at all. Sometimes I can flip the switch a couple times and they come on and other times I have to pass my propane heater under them for a couple minutes before they come on. Running a heater on an already hot and humid day is not the least bit desirable, not to mention that it's robbing me of already precious shop time. This happens even if they are only off 7-8 hours overnight.
Does anyone have ideas on how I could eliminate the problem? Would humidity be getting into the ballast? Could I do something to seal the ballast without causing a heat buildup?
Geoffrey
Geoffrey
