A few questions about single vs. double acting 12 volt hydraulic pumps guys. I have quite a bit of hydraulic experience, but I've never worked with these 12 volt pumps before.
It looks like the single acting pumps have one port; hydraulic fluid goes out the port under pressure, there is a check valve to keep cylinder from retracting when the pump stops, and a solenoid valve bypasses (or opens?) the check valve when you want to retract the cylinder?
On the double acting pumps there are two ports, and I'm assuming the motor reverses in order to determine which port the pressure is coming out of? Does the pump draw in hydraulic fluid from the "return" line, or does the fluid just return to the reservoir? Lastly, can a double acting pump be used in a single acting application?
I'm helping my cousin build a fish house frame and he wants hydraulic lift instead of hand winches. TIA
