OT- small diameter turning
Results 1 to 10 of 10
    Nov 2014
    Florida
    6,185
    2451
    3074
    Default OT- small diameter turning
    I just asked our manual lathe guy if he could turn a piece of 1/2 hard brass .012" dia x .13 long. He said "yep, no problem, done them before" !!
    Anyone else doing turning that small?
    Feb 2014
    FL
    4,194
    13436
    5001
    With no tolerance on straightness, roundness, or diameter, sure I can make it.
  3. Likes Bobw, Straightedge, Bill in PA liked this post
    May 2019
    Michigan
    2,522
    1403
    1920
    Quote Originally Posted by TeachMePlease View Post
    With a belt sander..??
    May 2017
    FINLAND
    2,450
    663
    1144
    0.012" ?
    Ha, that qualifies as a bar stock
    This was about 14 micrometers or 0.00055 inches in diameter:
    Any smaller than that and you need damn electron microscope to set the tool center height
    rest of the thread if someone is interested: Digital microscope for lathe work
  6. Likes DrHook, jz79, sfriedberg liked this post
  7. #5
    Feb 2006
    Indiana
    13,812
    792
    4579
    Any watch repair person, the kind that can make balance staffs, not just replace batteries, can turn and polish hardened steel to around .005 inch diameter. Smaller diameters would seldom be needed, but I never did a ladies' wrist watch staff, so I don't know their dimensions.
    The trick is to have a good lathe that turns at high speed. A Hardinge lathe with a 5C spindle and 3500-4000 RPM can do surprisingly small work. Hardinge makes 5C collets with stock size order holes as small as 0.016", 1/64" or 0.5 mm. But watch lathes are much smaller and faster and watch lathe collets are made with order holes as small as 0.1 mm.
    Turning brass to .012" x .13" is a trivial job for a watch lathe with a slide rest. I will explain that most watchmakers never use a slide rest because most watch work can be done with hand-held tools faster and maybe even better.
    Larry
  8. #6
    May 2019
    Michigan
    2,522
    1403
    1920
    I calculated the RPM needed to run that part at 1000 sfm.
    314,000...!!
  9. #7
    Mar 2001
    Switzerland
    2,710
    3024
    1266
    I routinely do balance staffs for very small high end watches, length around 2.2mm is common (.087"), sometimes as short as 1.6mm (.063"), pivots on those are typically .065mm or .0026". 2 pivots, one at each end, largest diameter on the part would be 1.5mm typically with about 4 other diameters and a critical taper.
    That's in steel, would be tricky to do in brass but .012" in brass a piece of cake.
  10. Likes L Vanice liked this post
  11. #8
    Nov 2003
    5,862
    208
    2010
    And that is why smaller lathes, with higher spindle speeds, are generally used for such work. In my shop I would use my Unimat instead of my SB.
    But then, I consider such calculations as guidelines, not rigid dictates.
    Quote Originally Posted by ChipSplitter View Post
    314,000...!!
  12. #9
    Feb 2004
    peekskill, NY
    26,686
    6089
    Heck I can do that job with my harding 5/9 lathe. Key is to start with 1/4 inch stock and take it all off with one whack.
    Dead sharp tool, too.
  13. Likes JST liked this post
  14. #10
    Feb 2004
    peekskill, NY
    26,686
    6089
    OK I cheated a bit, I used the antique lathe for this, also I screwed up and made it
    too long. Have to get a heavy duty set of cutters to short it to 0.130 inch long.
    Attached Thumbnails Attached Thumbnails small_brass_2.jpg   small_brass_1.jpg   small_brass_3.jpg
  15. Likes old_dave, TeachMePlease liked this post
