OT Stainless steel for exhaust studs?
Likes Likes:  0
Results 1 to 16 of 16
    Mar 2008
    Vermont
    1,207
    75
    Default OT Stainless steel for exhaust studs?
    Quick materials question. I have to replace the crossover pipe on my old Chevy truck. Of course the studs on the manifold were toast, and I've drilled them out, ready to thread, no sweat there. This time I'm not prepared to spring for the 12 dollar apiece Chevy studs I got last time, and plan to use either bolts or threaded rod (3/8 inch coarse). There's insufficient room on the top of the flange for bolt heads, so I expect to thread the studs into the manifold as usual. My simple question is whether there's any material reason not to use some stainless threaded rod I happen to have, rather than the mild steel normally used. Any reason stainless wouldn't be suitable for this application?
    Oct 2009
    Oregon
    4,979
    5399
    2555
    Many modern diesel engines use really nice bolts and studs on exhaust components. I overhaul B series Cummins engines regularly and find the exhaust manifold bolts and turbo studs come right out with hand tools after 20+ years and lots of miles. They do corrode, but just surface (400 series?) They are very strong too.
    If you can tap or helicoil your manifolds to 10mm thread I'm certain you could find a really nice stud and nut combination from a pickup sized diesel engine that would suit your needs.
    Aug 2004
    British Columbia
    85
    No reason at all that I can think of.
    As a matter of fact, stainless exhaust studs are available as an aftermarket upgrade.
    Been a while since I worked in an automotive shop but I remember when GM used to use brass studs in their exhaust manifolds.
    Jan 2004
    Halifax Nova Scotia
    1,815
    273
    I replaced the studs on my former truck with 316 stainless and and aluminum bronze nuts years later they still came apart easily. The key is to use stainless studs and bronze nuts. The first time I did this I used stainless nuts and they welded themselves solid to the studs after only a couple days of using the truck. Lesson learned . Stainless on stainless with heat is a recipy for trouble. I then had to make new studs and used aluminum bronze nuts and had great success
    Jan 2008
    Merced, Calif
    1,046
    1257
    220
    Default SS
    Quote Originally Posted by Frederick Harvie View Post
    Ditto, Amen. You could even use plated nuts.
    Mar 2008
    Vermont
    1,207
    75
    Thanks, folks. I figured it ought to be all right, but worth asking.
    Sep 2006
    Sacramento County, California
    4,035
    2525
    1455
    Aluminum bronze nuts were mentioned above for use with stainless steel studs. That's a good idea. Stainless steel nuts on stainless steel studs will have a tendency to gall.
    Other than that, stainless studs are a good idea with the proper nuts.
    Mar 2009
    742
    23
    43
    Good ol' copper anti-seize on things doesn't hurt, either.
    Jul 2006
    Australia (Hobart)
    3,779
    587
    2881
    Quote Originally Posted by bruto View Post
    My Yanmar marine diesel came standard with s/steel manifold studs. The engine is over 20 years old and the studs are in perfect condition.
    PDW
    May 2003
    Iowa
    10,490
    3616
    4281
    Most of they high heat stainless bolts are made from 330. It's good for over 1500F before it looses strength. Most of the hardening stainless like 416, 17-4, etc. are only rated to about 1100F before they loose strength.
    If you're doing exhaust work, use nickel anti-seize instead of the copper.
    We do stainless nuts on stainless studs all the time.
    JR
  11. #11
    Dec 2006
    NW Ohio, USA
    291
    31
    We've made millions of OEM stainless exhaust studs, all out of A286
  12. #12
    Mar 2008
    Canada
    1,140
    6771
    209
    The diesel mecanic that works on my VW diesels always uses
    bronze nuts for the exhaust manifolds and turbos.
  13. #13
    Jun 2006
    Beaverton, OR
    5,458
    57
    You could also do what they do in vacuum systems that are baked out. They coat the bolts with silver plating. Stops them from seizing up.
  14. #14
    Mar 2008
    Vermont
    1,207
    75
    If I silver-plated the bolts on my 88 Chevy truck, it would probably double its value.
    Thanks again to all for the interesting observations, even though some seem a bit exotic for getting the headpipes back on my old beater. Since I already had the stainless threaded rod, I've gone with that, cut pieces to size, ground 1/4 inch square ends on to facilitate screwing them in, and bought some brass nuts. Now all I need is for it to stop raining so I can get underneath it and finish the job.
  15. #15
    Nov 2006
    Austin, TX
    119
    Why not just go with a set of thease? They will not back out, and they are also easy to remove.
    Welcome to STAGE 8... Call Us Now! 1.800.843.7836
  16. #16
    Mar 2010
    CA
    529
    15
    154
    For the exhaust studs on the race car I use stainless studs with copper nuts. I have never had a problem and no more snapping studs when you remove them.
