OT- Suggestions for rollup door...to move with less resistance ?
Results 1 to 9 of 9
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,545
    3014
    5890
    Default OT- Suggestions for rollup door...to move with less resistance ?
    The usual deal with chain to raise lower...as pictured...10 x 12 in this case. Tracks are not bent but door a bit difficult to raise and lower (and noisey as heck)....been that way for years but using it more now.... what might aid the sliding without attracting dirt...teflon tape ? special grease ? or ?
    Jan 2007
    Norfolk, UK
    20,681
    16105
    16534
    An electric motor?
  3. Likes kb0thn liked this post
    Feb 2017
    719
    8
    292
    If you are having difficulty, I would suggest reviewing the tension on the spring. The door should be relatively neutral for raise/drop if the spring has the correct tension. If there are gears, maybe some grease?
  5. Likes Red James, boslab liked this post
  6. #4
    May 2019
    Michigan
    2,412
    1250
    1770
    There's this new stuff called WD-40. It's all the rage.....................
  7. #5
    Sep 2002
    People's Republic
    5,225
    617
    3239
    Accidentally turn off your security cameras and have someone that you don't know drive into the door and use the insurance money to buy a regular overhead door[and pay the 'strangers' bar tab
  8. #6
    Jul 2004
    central NC
    2,635
    37
    700
    First, confirm the spring tension is correct. They fatigue over time and need to be tightened. Then clean and grease or oil the chain. I just wiped off the old grease and applied new grease to the lead screw in my door opener and it made a HUGE difference in sound.
    Dont EVER use WD-40 as a long term lubricant.
  9. #7
    Apr 2004
    Modesto, CA USA
    8,073
    1491
    Do not get old. Tighten the spring, drench gears with solvent, then lube.
    Bill D
  10. #8
    Aug 2004
    Virginia
    2,622
    198
    1109
    I think that was meant as a joke Steve.
  11. #9
    Sep 2002
    People's Republic
    5,225
    617
    3239
    True, do not underestimate the glue factor of old grease. Took apart a 50 year old window motor and the arm would not move in the channel[60s GM style]
    fresh oil sped it right up
