OT: Tape to stick on bottom of metal drawers to stop metal on metal sound
Results 1 to 20 of 20
    Jan 2006
    Brookfield, Wisconsin
    4,553
    361
    518
    Default OT: Tape to stick on bottom of metal drawers to stop metal on metal sound
    Want to get rid of the scraping sound from the drawer sliding on the cabinet. Thinking I should use some kind of sticky tape on the drawer sides and bottom or on the cabinet's rails. Some sliding resistance from the tape isn't a problem. The metal on metal sound is irritating.
    Feb 2005
    Ohio
    1,249
    1622
    242
    UHMW tape works for me.
    Mike
  3. Likes Spud, Toolznthings, Larry Dickman liked this post
    Jul 2006
    Hillsboro, New Hampshire
    14,330
    3135
    9528
    Quote Originally Posted by mister honey View Post
    Mike
    And it's easy to buy: McMaster-Carr - Plastic Tape
  5. Likes Spud, 52 Ford, Toolznthings liked this post
  6. #4
    Jan 2011
    Michigan
    250
    127
    Mike
    Works on heave wooden drawers also.
  7. Likes 52 Ford liked this post
  8. #5
    May 2021
    Virginia
    346
    374
    89
    As mentioned - UHMW. I'll add PTFE in there, too.
    McMaster-Carr Page:
    McMaster-Carr
    Sent by telegraph using - .- .--. .- - .- .-.. -.-
  9. #6
    Mar 2009
    6,604
    131
    1275
    Contact cement a strip of formica on each cabinet rail.
    Run a block of candle wax on the shinny formica.
    Insert drawer and it will slide in silence.
    (Did this myself)
  10. #7
    Mar 2006
    Vershire, Vermont
    2,829
    1985
    934
    Or just candle wax or paraffin, whatever you use to lube screws.
    Is there room enough to install full extension drawer slides?
  11. #8
    Feb 2010
    ch
    3,459
    287
    480
    before you do all the work, try some dry film lubricant first. they often call themselves "ceramic", "nano" and similar nowadays.
  12. Likes Mtndew liked this post
  13. #9
    Jan 2014
    Temecula, Ca
    3,495
    1441
    4528
    turn up the radio
  14. Likes atex57, digger doug, Mtndew liked this post
  15. #10
    Jan 2006
    4,553
    361
    518
    Looked at the McMaster Carr site.
    What is the difference between PEET , UHMW and PTFE tape ? Anyone used all three knows what each is best at?
  16. #11
    May 2014
    Massachusetts
    167
    8
    40
    Quote Originally Posted by Spud View Post
    You mean PETE (i.e. polyester)?
    PTFE (or TFE) “Teflon” would be the slipperiest, UHMWPE (ultra high molecular weight polyethylene) should wear better/longer.
    PETE (or PET)… not sure; maybe not as good as the other two?
    I might try UHMWPE first.
  17. #12
    May 2005
    AZ
    2,553
    260
    876
    I think that "PEET" is actually PEEK. McMaster has PEEK tape, which will likely be by far the most expensive. It's a highly resistant tape for chemical exposure and elevated temps, and thoroughly wasted on an application like this, IMO.
    I would go with the UHMW tape. It's very durable and should be slippery for quite some time. Clean the surfaces well where it will be applied, and it will likely lasr forever.
  18. #13
    Jul 2006
    14,330
    3135
    9528
    I'd also suggest the UHMW tape, but clean not only the surface to be adhered to, but the surface it will slide against. The tape is soft enough to pick up and hold particle, and so will become a lap of sorts if it gets too dirty. There goes your smooth sliding effect, and over time your support surface.
  19. Likes 52 Ford liked this post
  20. #14
    Jul 2006
    rochester, ny
    2,401
    609
    791
    I've used a fair amount of UHMW tape over the years, plenty slippery enuf, and much less $$$. The real issue is keeping it stuck in place. Once an edge gets loose, it just starts to peel off. Would be good to extend it beyond the contact surfaces and include a mechanical fastener, should last forever with that, or until crap gets imbedded in it. We're only talking occasional opening and closing, not continuous 24/7 reciprocal motion.
  21. #15
    Jun 2012
    Michigan
    6,283
    5879
    4022
    Quote Originally Posted by Larry Dickman View Post
    turn up the radio
    It took me way longer than I care to admit before I got this.
  22. Likes Larry Dickman, 52 Ford liked this post
  23. #16
    Apr 2006
    Manchester, England
    9,252
    1559
    6190
    Another vote for candle wax.
    Regards Tyrone.
  24. #17
    May 2021
    Virginia
    346
    374
    89
    Quote Originally Posted by MrSteve View Post
    Prolly mean't PEEK - which I have no experience with, so I can't comment on how it performs.
    I seriously doubt Pete would be a good substitute to UHMW tape... maybe get Pete to put the tape on the drawer bottoms?
    Also, who's Pete?
  25. #18
    May 2021
    Virginia
    346
    374
    89
    Good point. Like wood bearings.
  26. #19
    Jan 2006
    4,553
    361
    518
    Was a typo in previous post. Meant to type PEEK.
  27. #20
    Mar 2009
    6,604
    131
    1275
    If you use that tape you should put it on both surfaces. Not only one surface, which will surely abrade away when a heavy metal drawer is sliding on it.
