Trboatworks
- Oct 23, 2010
- Maryland- USA
Some friends just bought a sort of mid level RV a 5500 pounds or so, dual torsion axles and set with a sway bar rig on tow vehicle.
I was working with them as they tried to learn how to back the rig in a parking lot and wow the front and rear axle were out of alignment.
Really weird- looked like extreme positive camber on right front wheel and less so on left.
What’s up.
Is backing loading the rear axle enough to relieve the load n front pair and make the unloaded pair change camber?
Or both sets change load enough to make them look way out.
I’m talking like 2” difference.
I started grabbing the tire and giving it a shake to see if the lug nuts were loose or the bearing play way out.
What’s the deal- optical illusion?
I followed them to the parking lot and all looks fine while moving forward.
What’s up.
