matt_isserstedt
- Dec 15, 2003
- suburbs of Ann Arbor, MI, USA
Thanks all for helping me thru my myriad of concrete questions...
...latest burning question revolves around moving the concrete from a truck to be placed in the slab.
A couple of specifics, 25' x 40' size, only accessible on 2 sides due to existing buildings. There will be a stem-wall sticking 8" higher than the finished floor, around the full perimeter with a cut-down for a 9 foot garage door. Expected pour of 18-20 cu yards for 5-6" slab. Field of #4 rebar tied 16" on center throughout the slab, on 2" chairs.
Calling various ready mix places they all seem to agree on the cost for a pumper truck being in the close neighborhood of $1k.
The concrete truck chute would seem to have a range of around 15 feet but that is a long way to move seeing that only half of the area is directly accessible.
I can rent something like a Whiteman (its a brand name...) gasoline powered concrete buggy around $120-150 per day which seems like a lot of savings.
The functional sticking point is traversing the field of rebar with the buggy. It seems like if I layer some sheets of plywood for support of the load (estimating 3/4 yard @ 3000 lbs + buggy weight) and then suspend the ply above the rebar grid with something like a group of 2x6 or 2x10 blocks laid flat between the spaces of the grid, I could accomplish it via having a buggy driver dedicated to running back and forth.
I also don't have a good feel for how much concrete is "wasted" in priming the pump truck..the booms are like 30 meters/100 feet so it seems like there would be some extra that would have to be ordered.
So I seek the sage advice of the membership...spend the extra for the pump truck, use the plan above, or something completely different? Thanks in advance.
