rons
- Mar 5, 2009
- California, USA
A 3' x 5" square with a ellipse in the middle. A sheet(s) of stainless with a drain slope on all sides (like a ant hill).
All four edges bent 90 degrees down to allow water to drain. Bending a drain slop and a 5' long 90 bend is not going to happen
here using one large sheet. A cool job would look like it was pressed into the shape.
I could easily cut up cardboard and construct a model. Then weld four sections together. A long seam will warp. So maybe no good.
So what about a stucco or concrete solution?
Float in a slope with what? And doesn't the mix need an additive so that there is adhesion to paint. The slope height is 3/4".
