OT- Triangle Area Question / 6th Grade Math
Page 1 of 10 123 ... LastLast
Results 1 to 20 of 183
    Jan 2005
    Houston
    6,245
    788
    3007
    Default OT- Triangle Area Question / 6th Grade Math
    OK....it's been many decades since I was in 6th Grade, and no, it was not my final year of schooling.
    So here's my dilemma - the problem below is "Solve for the area of this triangle".
    My position is that it can't be solved as there is not enough information given.
    Am I wrong?
    Jan 2005
    Houston
    6,245
    788
    3007
    Yes...if it is a right angle triangle. But that one is clearly not.
    Jan 2017
    Oregon
    3,606
    761
    2503
    It's 1/2 of a parallelogram, so answer is 36.
    Feb 2004
    peekskill, NY
    25,299
    5149
    I think it's missing an angle somewhere. You can draw the hypoteneuse of the small implied right triangle (the one you need
    to the area of to solve the overall problem) at any angle.
  5. Likes GregSY, James H Clark liked this post
    Jun 2015
    Colorado
    570
    1167
    230
    Quote Originally Posted by GregSY View Post
    The height is given as perpendicular to the length and that's what matters here. If you were given the actual length of that non-perpendicular side then you would need more info.
    Jan 2007
    Norfolk, UK
    19,856
    15294
    15572
    Am I wrong?
    Not IMO, for without an angle or length of hypotenuse, that is nothing more than a drawn shape.
  8. Likes 4GSR, DrHook liked this post
  9. #7
    Sep 2014
    Georgia
    385
    300
    147
    jancollc and BugRobotics are correct. (Height x Width)/2
  10. #8
    Jan 2005
    Houston
    6,245
    788
    3007
    Quote Originally Posted by BugRobotics View Post
    This answer would allow me to reach an answer....but I'm not sure it makes sense just yet!
  11. Likes BugRobotics liked this post
  12. #9
    Apr 2006
    missouri
    221
    90
    59
    36 square inches
  13. #10
    Oct 2008
    Central Ohio, USA
    1,965
    847
    568
    Area = 1/2 x Base x Height
  14. #11
    Aug 2008
    Sussex, England
    3,439
    13
    773
    Quote Originally Posted by jancollc View Post
    Yep.
    Area of a parallelogram is base x height ie 12 x 6 = 72 in that case. The triangle is half of the parallelogram so area is 36.
    Of course you can figure out everything else about the triangles via the area of the parallelogram. Can be a very useful approach when you don't have enough information to go straight to trigonometry.
    Clive
    Need to work on my typing speed!
  15. Likes Limy Sami liked this post
  16. #12
    Jan 2007
    Norfolk, UK
    19,856
    15294
    15572
    Oh well, that's something I've learned today.
    Thanks guys
  17. Likes Screwmachine, Demon73, DrHook liked this post
  18. #13
    Nov 2013
    Eastern Massachusetts, USA
    5,476
    5197
    5241
    If you had an accurate drawing to scale it could be solved by drafting methods plus trigonometry. Once divided into two triangles with one 90 degree corner the sides could be measured and each triangle would have 1/2 the area of a rectangle with the same dimensions. The unknown angles could be found using trigonometry.
    If a photo were imported as a layer into 2D cad you could draw a line from that corner tangent to the longest dimension and you would have your right angles. How you digitize the drawing is to place coordinates at the corners while zoomed in and then play connect-the-dots.
    I used to solve unknown geometry by using dividers on a photo and then transferring to paper. On one occasion I needed to "borrow" the dimensions of a motorcycle over-center stand from a photo in a magazine article. These stands are used for field maintenance such as removing wheels and have to be simple, light, and portable. The dimensions are criitical to ease of use.
  19. #14
    Jan 2020
    New Mexico
    16
    To solve a trig problem like that one needs a combination of side lengths and angles.
    1. Two sides and one angle.
    2. Two angles and one side.
  20. #15
    Jun 2015
    Colorado
    570
    1167
    230
    Maybe this will help...
    Take your triangle (blue), make another of the same size and orient it on top of the first (red) to make a parallelogram (parallelogram is 4-sided shape formed by two pairs of parallel lines).
    Area of a parallelogram is base * height. You have 1/2 of the parallelogram therefore... 1/2 * base(12) * height(6). So you can see how you've been given all the necessary info.
  21. #16
    May 2017
    FINLAND
    2,155
    585
    998
    Quote Originally Posted by Clive603 View Post
    Yep.
    Clive
    I think you can't fiqure out rest of the triangle from the information given. Area is just constant even if the angles and dimensions vary wildly.
  22. Likes SeymourDumore liked this post
  23. #17
    Jan 2002
    West Coast, USA
    8,428
    570
    5946
    I was going to go along with all the others who saw the 6" as height, not length of a side, and the answer easy.
    But then I realized this was in English units and impossible to solve, unless it were metric . . .
  24. Likes Bobw, atex57 liked this post
  25. #18
    Feb 2004
    peekskill, NY
    25,299
    5149
    That's the area of a right triangle with a 6" side. Your answer overstates the area by
    some amount.
  26. Likes Murf liked this post
  27. #19
    Jan 2017
    Oregon
    3,606
    761
    2503
    Quote Originally Posted by jim rozen View Post
    some amount.
    Um, no.
    A rectangle is a parallelogram, but a parallelogram is not necessarily a rectangle.
    The formula for area of a parallelogram, as prev. posted, is A=bh. Since the triangle is 1/2 of the parallelogram, it's area is 1/2(bh).
    Information given, you cannot solve the full triangle. But you can solve for area no problem.
    It's not a trig problem- it's basic geometry.
  28. Likes tdmidget, DrHook liked this post
  29. #20
    Jan 2014
    Temecula, Ca
    3,276
    1396
    4259
    for fucks sake, if you don't get it, draw it up in cad and analyze the area. It's 36
  30. Likes SVE Performance liked this post
