OT- Triangle Area Question / 6th Grade Math - Page 3
Page 3 of 10 FirstFirst 12345 ... LastLast
Results 41 to 60 of 183
  1. #41
    Virginia
    31,369
    7561
    9844
    Quote Originally Posted by metalpyro View Post
    I thought the unknown angle would make a difference in the area.
    It doesn't.
    Change ANY angle, it does change the area.
    Be unawere of the value of any angle NOT changed?
    It matters not what it is.
  2. #42
    Aug 2005
    CT
    7,969
    353
    1966
    Quote Originally Posted by GregSY View Post
    All I know is I can easily figure out answers to math problems....but not if I have to follow the modern methods which are far more complex than needed.
    As a father of a 26 and a 22 year old girls, I was the lucky one to help them through their first ( and second, then third and .. ) steps in math and algebra.
    They on the other hand were the unlucky ones who had to put up with my "old" methods of math and algebra.
    To boot, not only old but a European version of it!
    In any case, there is some method behind the madness of "new math" teaching, but it certainly isn't logical to those of us with the ancient experience.
    Both kids aced the high school classes, then went onto college to ace that one too, one already has her masters, the second one is starting it in Sept.
    Point of all this is that they both have told me that it was my method that got them through the "growing pains" of math learning, even though they eventually adopted
    the new techniques. Showed me some of it, but most of that shit still don't make sense. It obviously works, but doesn't make sense.
    As far as the original question, figuring out the area of a triangle is the only case where one need only 2 pcs of information: one side of a triangle ( base ) and the height of the triangle ( with respect to the base )
    For all other calculations, you need no less or no more than 3 pcs of information, pick any combination of the 3.
  3. #43
    Jan 2017
    Oregon
    3,628
    768
    2509
    Quote Originally Posted by SeymourDumore View Post
    ...For all other calculations, you need no less or no more than 3 pcs of information, pick any combination of the 3.
    I have a triangle. One angle is 90 degrees, one is 30 degrees, and one is 60 degrees.
    What is the length of the hypoteneuse?
  4. #44
    Aug 2005
    CT
    7,969
    353
    1966
    Quote Originally Posted by jancollc View Post
    Wrong example!!!
    You see, giving 2 angles of a triangle already explicitly defines the 3rd angle, ergo giving 3 enclosed angles might as well be only 2!
    In a similar manner, when you call a triangle a "perfect triangle", you're already providing 2 pieces of information: enclosed angles are 60 deg AND that a=b=c.
    Still need 1 more and ONLY 1 more data.
  5. Likes tdmidget, DrHook liked this post
  6. #45
    Sep 2004
    Arkansas
    59
    23
    Twice the length of the side opposite the 30 degree angle. If I remember correctly.
    Bob
  7. #46
    Jan 2017
    Oregon
    3,628
    768
    2509
    ..Still need 1 more and ONLY 1 more data.
    Lol. Just pointing out that of the 3 pieces of information, one of them needs to be a length.
    2 sides, 1 angle. OK
    2 angles, 1 side, OK
    3 sides, OK
    3 angles, not OK
  8. Likes DrHook liked this post
  9. #47
    Aug 2005
    CT
    7,969
    353
    1966
    Actually Janc, you could have gotten me!
    Let's say you give me the information:
    One angle is 30 deg, the other is 60, and one of the "lengths" is 2.
    Unless you tell me what the "length" belongs to, I am still SOL.
    And no, it does not need to be the length, you could have given me the area instead.
    Or for that matter you could have given me the area of the inscribed circle.
    Or the volume of the sphere created by the radius of the inscribed circle ....
  10. Likes jancollc liked this post
  11. #48
    Virginia
    31,369
    7561
    9844
    Keep runnin' yer keyboard!
    We'll have yah map the bugger onto the ONLY surface of ... a Klein bottle!
    How's that for a "special angle" on life?
  12. #49
    Nov 2003
    5,426
    188
    1810
    Perhaps this will help. And yes, the exact angles of the triangle or parallelogram do not make any difference at all. I have outlined the proof in these two drawings and at no point does any angle come into the argument except that the height is perpendicular to the base (90 degrees).
    First the area of a parallelogram:
    And then the area of the obtuse triangle using the parallelogram:
    And the answer IS 36.
    I trust that all here can mentally rotate the image in the OP's post 90 degrees to show the base at the bottom.
  13. Likes GregSY, MetalCarnage, DrHook liked this post
  14. #50
    May 2010
    DENMARK
    3,757
    4089
    12756
    It's as simple as given in post #10. The area (AREA) of any triangle is half the base x the height.
    From the info in the OP area is all that can be determined.
    What does surprise me is how many suggestions have been given
    To brush up on old knowledge how many 1" steel balls will weigh the same as one 2" steel ball? I'm always surprised how few get that right.
  15. #51
    Mar 2017
    LATVIA
    546
    140
    269
    whoa, we're having problems with 2D here and you're adding a 3rd one... slow down there!
  16. Likes Gordon B. Clarke liked this post
  17. #52
    Virginia
    31,369
    7561
    9844
    Quote Originally Posted by jz79 View Post
    Best one I knowt of was due to a mis-print. Mostly-RC home-study school my kid brother jest retired from sent out a test with a question as meant to ask:
    "Which is heavier, lead or gold?"
    Time it had been so-called spellchecked, printed, and hit the field, the question was:
    "Which is heavier, lead or God".
    Grading for the kids was - shall we say - "finessed?"
    Grading Staff wasn't in a rush to find out if THEY got it right or not, EITHER!
  18. Likes DrHook liked this post
  19. #53
    Mar 2005
    Indiana
    4,772
    1263
    1200
    Quote Originally Posted by Gordon B. Clarke View Post
    It's been a while...but by my calculation (pen and paper, ha!) eight. Somehow, after all these years, I still have most of the mathematical formulas I've ever learned rattling around up in the old brain.
    The "new math" is something they came up with to try to make it easier for everyone to learn faster and push through more material quicker from what I gather. But it seems like it makes some things easier and some more of a pain in the butt to grasp.
    I teach my kids the way that works for them and the way they think through things individually. If they bring something home and don't understand it, then we go over it a few different ways until they do. If that isn't the teacher's preferred way, tough shit for the teacher. I am willing to go to the school about that if I need to. Haven't had to so far. Correct is correct if it's been arrived at with proper methodology.
    My kiddos both learned to read before kindergarten using the same book I learned with. They both knew their basic multiplication and division before the teacher ever brought it up in class. Giving them a good head start helps a lot. Also teaching them to look at things from different "angles" or perspectives when they don't understand something forms good habits for future learning of any subject.
  20. #54
    Apr 2018
    4,256
    1924
    Quote Originally Posted by eKretz View Post
    Is it ? the "new math" I am aware of started with SMSG and was based on teaching set theory. It was more mathematics, less arithmetic. Parents didn't like it then, either, cuz they couldn't do the homework
    But that was over 60 years ago ...
    by gosh, it's on wikipeedia...
    https://web.math.rochester.edu/peopl...rarm/smsg.html
    Worth a read. Funny.
  21. #55
    Mar 2005
    Indiana
    4,772
    1263
    1200
    Quote Originally Posted by EmanuelGoldstein View Post
    Yeah, it's different these days. Some of it really makes me shake my head in the "WTF" manner.
  22. #56
    May 2010
    DENMARK
    3,757
    4089
    12756
  23. #57
    Mar 2005
    Indiana
    4,772
    1263
    1200
    Erm, weight is proportional to volume, not area...
    I got 4.1888 in³/0.5236 in³ = 8.
  24. Likes Demon73 liked this post
  25. #58
    Sep 2010
    moscow,ohio
    6,345
    647
    2111
    the ammount of surface space contained within its borders.
  26. #59
    Mar 2017
    234
    104
    Set theory is the right place to start for training a mathematician, not a human calculator which is what math education is geared towards. Set theory is the very most basic & therefore abstract underpinning of mathematics.
    Cutting a piece of paper and rearranging the pieces is not a proof but rather a demonstration of a particular case.
  27. #60
    Mar 2005
    Indiana
    4,772
    1263
    1200
    Lol. Terrible. That last paragraph example was hilariously bad.
