OT- Truck CEL code P0030 repair more likely to involve replacing oxygen sensor or
Results 1 to 16 of 16
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,254
    2776
    5575
    Default OT- Truck CEL code P0030 repair more likely to involve replacing oxygen sensor or
    is it sometimes a blown fuse or wiring issue ? If so, any estimates of how often it is one issue versus the other ? 2011 Chevy Express w/ gas V8.
    Aug 2010
    Minnesota
    1,983
    150
    1462
    80%-90% of the time its a bad O2 sensor when you get a heater circuit code, the heating element broke. You can ohm it out, or key on and feel the sensor with your hand/ir gun and see if its heating.
    Aug 2006
    Virginia
    595
    812
    340
    I’ve found both bad sensors and blown fuses due to a short to ground on the heater supply circuit. And bad sensors are most common root cause. In my experience about 20 sensors to each wiring fault.
    Joe
  4. Likes Milacron liked this post
    Virginia
    25,744
    7561
    8122
    What Joe said.
    In the years I was in Hong Kong half and more the year, vehicle sitting, I'd need new ones every two years. Sta-bil in the fuel and change sensors or no Sta-bil and may as well change vehicles.
    ONE sensor on a MOPAR van, Pontiac sedan, Jeep/GMC cross-breed, or GMC p/u, not a big deal.
    Four of them on a Jaguar, and much more expensive, each? I don't let that one just SIT.
    Dec 2000
    51,254
    2776
    5575
    Great answers.... so now I may complicate matters by saying the vehicle is also throwing codes -
    P0053
    P0135
    P0442
    Would fixing P0030 likely clear P0053 and P0135 as well ? And could P0442 somehow be related as well ? Or could (P0442) gas fume escape actually cause the first three codes to come on ?
    The vehicle has not been used for months ..... if that might cause all this, how does it happen.... gas octane issues, or ?
    P0030 showed up prior to last "long sleep" and when reset with the OBD it came back within 20 miles of driving. Don't recall seeing the other three codes the first time the CEL came on...so wondering if vehicle sitting without use for so long might be related to any of this ?
    Aug 2010
    Minnesota
    1,983
    150
    1462
    Zero chance on the P0442 causing the rest... a large evap leak and an evap purge flow code would indicate a stuck open purge solenoid which will cause fuel trim related issues, but not a P0442.
    Sitting is hard on vehicles... with those codes almost 100% sure you have a bad O2 sensor. The evap leak, those are all over the place. Just check the seal on the gas cap.
  8. Likes Milacron liked this post
  9. #7
    Virginia
    25,744
    7561
    8122
    Quote Originally Posted by Milacron View Post
    P0053
    P0135
    P0442
    Long periods of sitting cause lots of things which may then cascade, yes. I cannot much be bothered chasing them until I have run the old tankful out and am at least 25-50% through a fresh fill-up, and a run long enough to get EVERYTHING up to temperature and keep it there for a while.
    I leave a reader/cleardown device connected that first old tankful. Now and then it may go into limp-home mode, need cleared at-speed.
    Several if not most - sometimes ALL - will have cleared by the first decent run on fresh fuel. THEN one chases any as are left.
  10. Likes awake liked this post
  11. #8
    Dec 2000
    51,254
    2776
    5575
    Quote Originally Posted by kustomizingkid View Post
    Possibly stupid question, but is there just one O2S ?
  12. #9
    Aug 2010
    Minnesota
    1,983
    150
    1462
    2011 is going to have 4, one pre and one post cat sensor per bank. The P0030 is Bank1 Sensor 1, so a drivers side front or upstreem O2 sensor.
  13. #10
    Dec 2000
    51,254
    2776
    5575
    Yikes...if any of the other 3 went bad would there be yet more codes other than the codes I am getting ?
  14. #11
    Virginia
    25,744
    7561
    8122
    Certainly!
    If you do not have the vehicle specific manual on CD and HDD, nor an analyzer that has them loaded for that vehicle with text explanation, you can find your vehicle by MY, etc and VIN range online to get the rest of the codes that KK implied explained.
    CAVEAT: There is more to it than just the code. Some circumstances will set a code as a byproduct of some other component fail. Many fails are just part of a more complex fault. Some faulting is situational and transitory.
  15. #12
    Dec 2000
    51,254
    2776
    5575
    CAVEAT: There is more to it than just the code. Some circumstances will set a code as a byproduct of some other component fail. Many fails are just part of a more complex fault. Some faulting is transitory.
    Hmmm...sounds familiar...like a CNC control that throws a strange code that ends up being low oil in the automatic way oiler.... or low parameter memory battery for one axis throwing about six more faults that all go away with a new battery.
  16. #13
    Aug 2010
    Minnesota
    1,983
    150
    1462
    An 02 heater circuit fault is 90% of the time indicative of one thing, the heating element failed. Now if you had lean codes for one bank thats a whole different story.
  17. #14
    Dec 2007
    Southeastern US
    6,400
    845
    2802
    Yea, bad heater in the O2. I'd toss a sensor in it, tighten the gas cap and clear the codes - drive it a bit and see what comes back.
  18. Likes Joe Rogers liked this post
  19. #15
    Virginia
    25,744
    7561
    8122
    Some autos even use the same bus technology and protocols as CNC, VFD, etc, do, and yes low battery Voltage can be an issue. But they are usually related in a rational manner if you grok the rest of the system, either case.
  20. #16
    Aug 2006
    Virginia
    595
    812
    340
    The heater circuit in GM drivetrains O2 sensors is a battery voltage circuit. Most sensor supply circuits are 5 volt circuits and are split into busses some with 5 or more sensors. If you lose one of those busses due to a short to ground you need to bring a lunch. As a result of the lower voltage on the sensor supply and signal circuits, high resistance in the circuits is an issue. Most connectors are weather protected as a result and terminal fretting due to vibration can rear its ugly head. Lots of faults can be cleared and fixed for a long time by cycling the connectors. I got into the habit of lubing every connector I manipulated with proper dielectric grease.
    Joe
