What is this "Rust" thing you speak of???
My '98 Dodge still has paint on the frame, and the factory exhaust. (minus the inside of the Cat).
I'm just rubbing salt in the wounds... I'm a Massoftwoshits native, and I am VERY familiar with the rust.
I don't know anything of the new stuff, others apparently do.. But how often do you have to touch your
brake lines? Every 10years? Just put new ones on.
Yeah Yeah Yeah.....
If you got the kind of snow & ice we get, with those hills....you'd be toast.....
10 years ? surely you jest.
3 years. and I don't try to "patch in" a piece with compression fittings.
Take a roll of the brake line, slid a new nut on, flare the end.
Tape the nut to the end, and cover the end.
Starting at the front grill, feed the line in, along the frame, all the way
to the back (tape keeps dirt from line, and nut from sliding to the front)
Make your connection in the back, come back up to the MS, trim line to size,
apply another new nut, flare the end (under the car this time, a wee bit tougher to do) and make the connection to the MS.
BTW those leetle rubber caps to fit the bleeders work well to keep them from
rusting solid (and snapping off), I have tried all sorts of things including
packing full of never seize etc. nothing works as well, the auto parts stores sell them.
