Antarctica
Hot Rolled
- Jan 16, 2007
- Annapolis, Maryland
Embarrassing to a ask such an 'amateur' question, but here goes....
New to me 2002 F350 7.3 Crew Cab Dually, manual shift, dana 80 rear. This has a truck camper on it that will live there full time. Took it on a maiden voyage with the TC about two weeks ago. Had a slight vibration at between 60-66 MPH.
I dropped the rear shaft(s - its a two piece shaft) suspecting a bad ujoint. With them out, none felt particularly suspect, but the rubber bushing around the carrier bearing was a little wore out. Pretty sure that everything was original - lots of rust, etc, so I decided to PM the whole thing - new u-joints and carrier bearing. I pressed out the old joints, which, again were pretty rusty, and started assembling the new ones. I'm not a u-joint expert, but I've done a few (10-12?) in my time. I replaced the original spicer joints with Moog 330's.
Bottom line: I've got them all in, sorta. Most were/are tight. I pressed them in and tried not to 'over press' them, but they basically needed to be squeezed all the way to get the snap rings in. They all move, but nowhere nearly as freely as the old one (to be expected). They are definitely tight enough that they will 'wear' in if I leave them.
One, on the bolted yoke that mates to the transfer case, would not accept the snap ring, but its mating face was not flat, and I was hoping that once installed and pulled down tight, it would 'open' the yoke enough to accept the last snap ring. I haven't tried it yet, but it was at least 10 mil from accepting the snap ring on the workbench. No - there are no pins that have fallen into the cap - its not that far off and I can tell that the caps are seated correctly against the cross.
So looking online, there are lots of folks that seem to have this issue with this particular (spicer) driveline and u-joint. Many ending up grinding the caps slightly. I could pull the one cap and turn it down 10 mil. Also, in digging around, I learned that Moog also has a 330a ujoint that is 10 mil smaller (by using thinner snap rings)- apparently there's a genuine issue with the correct length on GM and Dodge trucks (google Moog 330 vs 330a). Even replacement spicer joints come with an 'array' of different snap ring thicknesses.
so...
- Run it and let them 'wear in'
- Pull them and turn down the cap?
- Buy another joint and put in the thinner clips?
I know we have some driveline experts on here (Reed). Thoughts? I need this thing to be bulletproof.
so...
