OT: Use of the word "clocking" for rotational angle alignment
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    Sep 2010
    Vancouver Canada
    944
    703
    340
    Default OT: Use of the word "clocking" for rotational angle alignment
    Here's a silly topic for a Monday: In an engineering call this morning, which involves Canadians and Americans and both physicians and engineers, the use of the word "clocking" was discussed, as the (Canadian) physician didn't know what it meant. I know a lot of American engineers use this term to generally refer to having rotational angles set up correctly. The most common instance of this I can think of is timing belts and chains in cars where all the pulleys have to be at the right angle to each other before the belt goes on. But I am not convinced "clocking" is the most common term for this, so was curious to ask in this forum, which is suffused with wisdom in the mechanical arts. I'm sort of a physicist and part electrical engineer so I'd say something like "you have to get the phase angles correct". What terminology do you all use?
    May 2017
    Massachusetts
    339
    349
    170
    I have heard the term 'clocking' used exactly as you described on several occasions. Sometimes paired with 'timed' or oriented relative to each other.
  3. Likes Joe Rogers, Joe Miranda liked this post
    Virginia
    28,077
    7561
    8704
    Quote Originally Posted by rcoope View Post
    "HR will have your final paycheck ready by close of business, tomorrow."
    It is the relationship betwixt and among that has to "JFW".
    Otherwise:
    "Clocking" when, for example, seeking minimal TIR by finding countervailing errors by experiment. Milling cutter, holder, spindle taper, etc. Relationship not fixed, marked, nor known in advance.
    "Synchronizing" for a DOHC IC engine's cam drive gears, chains. or toothed belts, other mechanisms of rigidly related persuasion, that ARE known as such in advance, have but ONE "right answer", ELSE a limited set of same.
    Apr 2004
    Modesto, CA USA
    7,071
    1193
    I have heard of screw slots being aligned so they all point the same way. Such as electrical cover plate screws so the slots are vertical as"clocking".
    Spark plugs can be clocked so the gap faces the intake valve.
    Bill D
    Jun 2019
    341
    103
    297
    I have only ever heard it used as you describe. For vehicles timing is used, but in relation to say getting a part aligned in a rotary fixture or indexer it would be clocked.
    Aug 2014
    Indiana
    142
    107
    235
    Clocking is a common terminology for what you are describing.
    No, just no.
  8. Likes 310 Guy, cg285, dalmatiangirl61, mhajicek liked this post
  9. #7
    Dec 2003
    Washington
    4,727
    2235
    4078
    Another common term in a variety of industries is "Registration" . . .
    Print Registration being the most common where you ensure that adjacent color impression drums are in registration with one another (or clocked in the thread vernacular).
    We use this term a lot in motion control systems to ensure that one part of the machine is in registration with another part of the machine. When making toilet paper or household towel, you need to keep the perf knife in registration with the cut-off knife at the end of the roll - often done at web speeds exceeding 2000 fpm. We are doing a machine now that does laser marking of a formed steel part and we need to make sure that the laser mark is in registration with the parting tool to ensure that we don't cut through the mark when forming the part . . .
    Printing registration - Wikipedia
    Another word is "Indexed" . . . but I digress
  10. #8
    Virginia
    28,077
    7561
    8704
    Quote Originally Posted by Bill D View Post
    Bill D
    I'd class both of those as "aligned" (with...). As you did. And cease.
  11. #9
    Nov 2013
    Eastern Massachusetts, USA
    4,507
    4623
    4621
    Bill D
    I've also heard that described as spark plug indexing and perhaps indexing might be a more acceptable term to the others.
  12. #10
    Aug 2006
    greensboro,northcarolina
    2,417
    155
    602
    I've heard it being used to time two or more features in a round part, like a bolt circle, to a key way or set screw or even a gear tooth.
  13. Likes capnron1969 liked this post
  14. #11
    Jan 2007
    s w NH
    333
    234
    121
    been a machinist (and other things) since 1974 til 2017. "clocking" came out of the mouths of the old timers way back when I was young. could refer to actual indexing of a part by various means, or a way to locate the part correctly for the next cut so previously machined or just existing features, as in a casting would come out right.
  15. Likes mhajicek liked this post
  16. #12
    Nov 2003
    5,102
    180
    1588
    There are a number of words that I would consider better, clearer when used in different situations.
    "Clock" or "clocking" is perhaps most used in the UK when referring to dial and dial test indicators. This is probably due to the physical resemblance between the dial face of these indicators and the face of an analog clock. This seems to be a long standing usage and is probably considered proper in the UK and other places that were influenced by their usage.
    From that I get the impression that many types of alignment are referred to as "clocking" because those dial and dial test indicators (aka, clocks) are used in the alignment process. But this most frequently refers to a linear positioning: it's use for an angular one seems to be less common and probably related to an angular process that uses a DI, DTI, or some kind of circular device with a rotating pointer.
    I am a US engineer and I like using terms that are more precise and less likely to lead to misunderstandings. I have not either heard nor used the terms "clock" or "clocking" for angular alignment of any type. This is just not the best, clearest terms for any of these tasks. The terms that I would prefer would vary by the angular task that is at hand. So, if I were setting an apparatus to a desired angle, perhaps using a protractor style scale, with or without a Vernier, I would probably use the word "set" or "set the angle". Someone mentioned the alignment of two or more images. To my mind, image alignment is a linear task, not an angular one even when those images are being created with rotating drums. For such a task the work "alignment" seems to be more descriptive. And if you get into the rotation of the drums that are creating those images, then the word "synchronize" seems to be a better way to express what is needed.
    When spark plug timing is needed, the word "timing" is what I have seen commonly used and it is probably the best one for that situation.
    "Clocking" could be used in any or all of the above situations, but IMHO, it is not the best word to use. I suspect it is used in an attempt to appear to be "cool" and that is not a good or sound engineering practice (again, IMHO).
  17. #13
    Jan 2007
    Florida
    1,155
    138
    421
    i think in this example the term would be "anal" haha
  18. Likes capnron1969 liked this post
  19. #14
    Dec 2018
    ALAND ISLANDS
    5
    7
    I have heard of/used the term “clocking” in the automotive/industrial repair field to reference the reassembly of a part that could be positioned several ways around its central axis. Examples would be the mounting of a new or rebuilt turbocharger so that the flanges align or the nose cone on a replacement starter motor that allows for various application. We very commonly refer to this as “clocking”.
  20. Likes cg285, Joe Rogers liked this post
  21. #15
    Dec 2015
    Connecticut
    1,042
    26
    334
    “Proper angular alignment”
  22. #16
    Jan 2007
    Florida
    1,155
    138
    421
    Quote Originally Posted by capnron1969 View Post
    same, i was going to use alternator as an example (or a/c compressor clutch coil)
  23. Likes capnron1969, Joe Rogers liked this post
  24. #17
    Virginia
    28,077
    7561
    8704
    Quote Originally Posted by cg285 View Post
    "Alignment" "Analment".. ..I think some marriages end that way?
  25. #18
    Jan 2005
    Houston
    5,746
    546
    2533
    It's used for the simple reason that it is an understandable and descriptive term.
    'Proper angular alignment' is a bullshit term, in contrast. Why? For one thing, it makes you sound like you are given to airs. That's what happens when someone speaks in a 'fancy' way that is in fact less accurate. If it were more accurate, then it would be 'good speech'.
    Why is it less accurate? Because angles can exist in more than one plane. Something can be in 'proper angular alignment' in one direction and off in the other. But 'clocking'? A clock is flat and eliminates all the guesswork as to which plane you are talking about. Superior.
    Now, what's really a mystery is why some people use the term to describe walloping another person. As in, "Ed Earl up and clocked Jethro and knocked out his last tooth!"
  26. Likes capnron1969, tdmidget, JST, Joe Miranda liked this post
  27. #19
    Dec 2018
    ALAND ISLANDS
    5
    7
    GregSY gets my vote OT: Use of the word "clocking" for rotational angle alignment
  28. #20
    Jun 2013
    Oregon
    1,559
    553
    930
    Quote Originally Posted by GregSY View Post
    Clocking someone may just be short for "cleaning their clock "
