OT- Using E10 fuel in lawnmower - Page 3
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 103
  1. #41
    Oct 2005
    14,527
    Quote Originally Posted by hanermo View Post
    if the us government was to announce tenders for x gigagallons of alcohol for fuel in arizona, etc. Endless offers would appear at low cost.
    With eminent domain and no-permit hassles, input and output of water/fuel, rail or pipeline transport of end product foc from point of production.
    stop-right-there.
  2. #42
    Jun 2008
    TN
    1,545
    323
    250
    I have four good quality five gallon metal safety cans to keep gas in. All non-ethanol, of course. I put a little stabil in as I refill during the fall when I know I won’t use much until spring. Then I know that if I need to run the generator I have enough good gas to do so. And its no big deal when I know I don’t have to make a gas run because I already have gas. So its easy to plan the next fill up at my convenience. All my lawn equipment and motorcycles start and run great.
    I run the chainsaws empty when I think I won’t run them again soon. Start it, loosen the cap and turn the saw over and drain the tank. Shortly afterwards it stops. Leave the cap off for a day so the tank dries. Clean it up and put it away. One hard rule is to never, never leave ethanol pre-mix sitting in anything including gas cans. If you have to use ethanol pre-mix, use very small quantities that you can burn up within a month or less.
    I checked mileage in my truck and found that cost per mile is equal when the differential is as high as $.40 a gallon at the current prices. When the prices are closer, its less expensive to burn plain gas. I run some non-ethanol in the truck as well when its convenient and available. Interestingly enough, Ford recommends a tank of real gas at every oil change which is about 7500 miles or so.
  3. #43
    Apr 2007
    Pillager, MN
    5,702
    1861
    5173
    Ethanol and small engines is a joke............I only run premium non oxygenated in all of my small engines. And I have a lot of em'............... ..around 20+(?)................all premo and a dash of sea foam if they are going to sit for any length of time. I even leave gas in over the Winter, I run the tank as near empty as I can and just up the amount of sea foam. No tarnish or build up. Still smells like fresh gas come Spring. They all fire right up. Other stabilizers suck...especially Sta-bil......................The half dozen or so small engine guys I know will tell you not to run any alcohol, ever.
  4. Likes 5 axis Fidia guy liked this post
  5. #44
    May 2017
    Massachusetts
    268
    245
    130
    I can't begin to tell you how much free or cheap equipment I get because of ethanol. Lawn tractors, chainsaws, power washers, etc.
    A little fresh non-ethanol fuel. Sometimes a carb clean or replacement. Sometimes replace the fuel lines. That's usually all it takes to get them up and running again.
    And the dirty carbs are never the old-style shellac build-up. Always water-related fouling directly attributable to ethanol.
    EPA should be forced to calculate the environmental cost of all those replacement motors when requiring ethanol.
  6. #45
    Jun 2001
    St Louis
    17,834
    1780
    2966
    Yep, free equipment...
    The crud I see is crystals of "something". No idea what it is, for last one, I just cleaned it out and used the free mower. Maybe I should have kept it for analysis. Pinkish crystals.
  7. #46
    Nov 2018
    Michigan
    254
    121
    134
    Quote Originally Posted by JST View Post
    This past winter I filled up my snowblower to clear my driveway after our first big snow. Wouldn't start, just pissing gas out from the carb overflow port. Took it apart and found green gunk all inside. I've heard about pink crystals before, but this was green gunk preventing the float from moving and causing the whole pan to constantly fill. Cleaned it all out and it was running one pull later.
    I even ran it out last spring, so I was a bit puzzled as to why I had so much crap in there. Anyway, I learned a valuable lesson about testing snow removal equipment while the temperature is something above 10° and snow isn't getting into your fuel system while you got it open...
  8. #47
    Mar 2006
    Washington
    847
    92
    52
    The tech at a saw shop told me they called it “white rust” at Stihl school.
  9. #48
    Sep 2002
    People's Republic
    2,955
    212
    2053
    Might have problems with "Lead Fouling".
    Can't find some form of "Racing Gas" like Cam2 ?
    uhhh, what do you think is in Cam 2?
    why would a small engine have a lead fouling issue?
    In 4 stroke engines i think the ethanol issue can be overblown, or at least can be mitigated. 2 stroke I am not sure
  10. #49
    Sep 2015
    86
    72
    I've been running 100LL in a Stihl weed eater and a Tecumseh lawn mower engine for years. I've never drained either tank for the winter and they both start right up each spring.
    Not definitive, just my personal experience.
  11. #50
    Mar 2005
    Northwest Indiana
    3,920
    631
    720
    Quote Originally Posted by jmead View Post
    Yeah I've seen plenty of the white chalky stuff. Sticks needle valve bodies to the bores they're in like glue. PITA. No ethanol free gas by me... Wish there was. One benefit I guess, plenty of the aforementioned free equipment from the clueless around here.
  12. #51
    Oct 2005
    14,527
    I don't know about cam2, but it was recommended (we have allot of dirt track racers here)
    "Aviation Gas" the only left is "100ll" which has 5 times the lead of the red 80 octane I used to use in my cub.
    100ll is known to foul spark plugs with lead.
  13. #52
    Oct 2005
    14,527
    Quote Originally Posted by eKretz View Post
    Use the force Luke...:
    Pure-Gas.org : Map of Ethanol-Free Gas Stations in Indiana
  14. #53
    Mar 2005
    Northwest Indiana
    3,920
    631
    720
    Like I said, nothing close enough. Don't feel like driving almost an hour for a can of e-free gas. I'm almost all the way West in IN and almost all the way North. No blue dots over yonder.
  15. #54
    Apr 2005
    Beaverdam, Virginia
    7,240
    602
    3392
    Where I live everything is pretty much at least 45 minutes plus away. Looks like there are a few around by Lowe's, and I go there twice a month so I am good. Thanks to this thread I can get another hobby besides repairing carburetors.
  16. Likes digger doug liked this post
  17. #55
    Aug 2004
    Virginia
    2,267
    174
    818
    Thanks again for all the great feedback. Does anyone know if there is a relatively safe, easy way to remove the alcohol from E10? I'm just talking about a gallon or so once in a while. Is the alcohol more volatile then the gas? I know that alcohol absorbs water but it there something that absorbs alcohol and not gas? Just curious really.
  18. #56
    Oct 2005
    14,527
    Quote Originally Posted by crossthread View Post
    The ultralight air-o-plane crowd has been dumping in water, and then letting it settle out....or so I have heard.
    But then you have a toxic cocktail to dispose of.
  19. #57
    Mar 2011
    Geneva Illinois USA
    6,018
    2513
    2337
    Follow what is said in this post.
    How to Remove Ethanol From Gasoline | Sciencing
    The follow up of using anhydrous magnesium sulfate to remove excess water is one that is not covered elsewhere. Anhydrous magnesium sulfate is Epsom Salts that has been dried. There are procedures on the net to make the anhydrous from the Epsom salt. Here is one.
    Simply grind the MgSO4. 7H2O = Magnesium Sulfate Heptahydrate (Epsom Salts) into a fine powder first, then spread it onto large baking trays for maximum surface area. Heat to 250°C for 2 hours = 482°F Loses all waters of hydration. Yielding Anhydrous Magnesium Sulfate.Nov 7, 2007. You can also purchase the salt from Amazon if desired.
    Sciencemadness Discussion Board - Dehydrating MgSO4 completely???? - Powered by XMB 1.9.11
    A bit of work but for most people only a few gallons are needed for a summer.
    As to do with the alcohol/water and the filtrate, I see no reason that they both could be just dumped. There is nothing toxic about either one.
    Tom
  20. #58
    Jun 2001
    St Louis
    17,834
    1780
    2966
    Quote Originally Posted by TDegenhart View Post
    Tom
    Sort-of.
    The water can pull some percentage of other components, especially any that have some water solubility, or that get carried in the alcohol. Most of it will be gone if left to sit out for a bit uncovered, which is the same as dumping.
    Take a sample of the drained material and let it evaporate on a piece of clean glass. See what you have left.
    The water solubility of alcohol is high compared to its solubility in the gasoline, but there is such a thing as an equilibrium, which means not ALL the alcohol comes out, and not ALL the gasoline stays out of the water,
  21. Likes digger doug liked this post
  22. #59
    Oct 2005
    14,527
    Also, you will want to get all the water out, so will "overdrain"
    and some gas will make it into the trash.
  23. #60
    Sep 2002
    People's Republic
    2,955
    212
    2053
    most race fuel is leaded
    lots of people are using avgas for their small engines with success
