Here's a new one on me....bought a new Kenmore washer/dryer last year. It came with free delivery/installation and the 'technician' came and installed it while I was at work.
Past few months, I've been noticing a smell while the machine was running, and the clothes sorta smelled when I transferred them to the dryer. They didn't smell bad after drying, but also didn't smell that great either.
I've been wondering if something died in there (unlikely) or there was a buildup of some sort of sludge, etc. I finally decided today to take the machine apart until I found something wrong.
I pulled it away from the wall and went to pull the drain hose out of the wall...It kept coming and coming. It turns out the drain hose (plastic) has the usual accordion pleats but also straight sections. The idea is you cut it to length depending on where you install it. But the guy who installed it just shoved the whole length down the drain pipe. I could see that the last 6" or so were submerged in water. It looks like the hose curved its way around the P trap and was allowing 'vapors' to find their way back up the drain hose into the machine.
So...I cut the drain hose to a proper length, and ran two loads as a test....the smell is gone.
