OT - what is the fluid in a MOVA globe?
Results 1 to 8 of 8
    Oct 2006
    Annapolis, Maryland
    641
    12
    68
    Default OT - what is the fluid in a MOVA globe?
    A search of the web provided nothing definitive - so here goes:
    MOVA Globes
    Innovative Rotating Globe Decor - MOVA Globes, A Unique Elegant Gift (not an endorsement, they are a bit overpriced and tend of have problems, but are cool while they last, and I got one as a gift)
    have a clear plastic shell, then a globe inside floating in some sort of clear liquid. Using light, and an arrangement of magnets, photo cells of some sorts and a bit of magic, the globes turn inside the shell.
    They are notorious for getting air bubbles in them. With a bubble, the globe is no longer suspended, and doesn't rotate.
    Easy enough to drill a small hole, and refill, but what is in there? The maker describes it as 'totally safe' and similar to charcoal lighter fluid. They say it is a 'proprietary fluid', but that is probably just marketing. They will sell a replacement globe, but not very cheap.
    So I am thinking it is a light paraffin / mineral oil of some sort. Any one know? Fluid density is critical, but since I need to top-up such a small volume, I think just making sure it is miscible and doesn't cloud is the biggest concern.
    Thanks in advance.
    Matt
    Nov 2018
    Michigan
    131
    54
    68
    Send a few drips out to someone with an FTIR? That should give you at least the basic composition.
    May 2017
    Massachusetts
    200
    130
    92
    Marine compass fluid might work. My recollection is it's something like mineral oil (but gin has worked in a pinch).
    Jun 2001
    lancaster,ohio.43130
    894
    14
    127
    How does One get home using gin?
    Sep 2006
    SW Wisconsin
    449
    11
    102
    Quote Originally Posted by mark costello View Post
    From one lamp post to another. ;-)
    Ed.
  6. Likes adama, TeachMePlease, Ron Hofer liked this post
    Dec 2012
    AUSTRALIA
    1,366
    5
    421
    If the globe is from China,the fluid is very likely a PCB.....non flammable,and non conductive.
    Jul 2008
    Asheville, NC
    2,356
    1117
    1066
    Maybe Stoddard solvent, which is water clear varsol. This is what was in my aircraft compass. I talked to the A & P mechanic at the airport when my compass leaked down. He said "get a cup full out of that 55 gallon drum over there, take out the plug on top of the compass & fill it". Problem solved.
    White spirit - Wikipedia
    Paul
  9. #8
    Nov 2004
    Webster Groves, MO
    6,738
    1669
    2967
    Quote Originally Posted by paul39 View Post
    Paul
    Airpath compasses are made here. George Cottrel, who started the company, told me that they used Stoddard's solvent. He also used it for cleaning fluid.
    Bill
