Trboatworks
- Oct 23, 2010
- Maryland- USA
I have a job where I need to dispense a couple of thousand feed of viscous putty into seams and need something with more balls than a caulk gun to use.
I am going to have to put the loaded gun into a boiling water to keep the mix fluid enough to dispense and there are volatile components in the mix so I am figuring the more complications in the gun the better chance some set up goo will screw up the gun.
A option though is to just buy half a dozen guns and toss them when they pack up..
Are there heavy grease gun like dispensers without the piston pump?
I don't know- a screw auger to drive the plunger in the body?
Best would be something that has disposable liners that can be filled and heated then placed in gun.
I don't know- I can place them in plastic ziplock bags in a hot water bath to keep them ready to go.
I am really shy of a battery operated rig as I don't want to be fighting charge downtime to get through the work.
Pneumatic would be ok if it has the balls to drive a stiff mix.
I am looking around and not hitting on a ideal setup- any ideals on what to buy?
I can just go the grease gun route and figure on a solvent scrub to keep it going but... what else is out there.
