OT: what year Ford powerstroke engines to avoid? - Page 5
Page 5 of 5 FirstFirst ... 345
Results 81 to 88 of 88
  1. #81
    May 2011
    New Jersey
    2,945
    290
    1621
    Quote Originally Posted by Garwood View Post
    1160/3208 don't have a great reputation. They don't like sustained load under turbo boost.
    IH DT466 was built to compete/dominate the same market 3208 was used in and it did with 30% less displacement. The most desirable DT engines used Bosch fuel systems. Cummins C8.3 came a bit later and does a fair job as well.
    Dt466 was a well built motor that was used for many years. We have a 98 fire truck with a 8.3 cummins, 300 hp I believe. It's a slug.
  2. #82
    Oct 2009
    Oregon
    6,027
    6501
    3363
    Quote Originally Posted by plastikdreams View Post
    How much does it weigh? I have driven a pumper with a 3208/MT41 weighing 18k empty. No thank you sir.
  3. #83
    May 2011
    New Jersey
    2,945
    290
    1621
    I weighed it at 38k with a full tank of 1250 gallons, even empty its just slow. Granted it's a truck not a car, but it tops out at 65 and hit a hill and it struggles.
    On the other hand we have a 09 freight shaker with a 435 mb/dd engine that scales at 48k full and its quite the mover...drain the 2750 gallons and it's surprisingly quick.
  4. #84
    Oct 2009
    Oregon
    6,027
    6501
    3363
    That's way too much weight for an 8.3. Who spec'd that truck??? an 8.3 has around 600 lb/ft @ 1500. That's very slow going in a 30K lb rig.
    435 DD makes 1550 Lb/FT @ 1200 RPM.
    Massive difference in powerplants there. 8.3 should not be in a chassis grossing over 26k unless it's a crane, concrete pump or an armored truck or something nobody cares if it's the slowest thing on the road.
  5. #85
    May 2011
    New Jersey
    2,945
    290
    1621
    Our last 2 trucks were spec'd by retards...I think ours is 300hp 860 ft/lb
  6. #86
    May 2002
    South Central PA
    14,591
    2829
    4327
    IH trucks with the DT466 were hot on the used market, I was told it was because it had wet sleeves and could be inframed inexpensively.
  7. #87
    Oct 2005
    21,705
    It's done to win bids for the lowest cost.
  8. #88
    Dec 2012
    AUSTRALIA
    4,416
    22
    1615
    The DT 466 was a great motor....ours were replacement for the previous years Cummins VT 555,possibly the worst POS ever put in a truck.....except for the Cummins V 185,which was an even worse POS.....The DT466 was a German designed tractor motor,which also went well in trucks......only 210hp,which would nt suit many here.......However ,sleepy joe is set to put all your gas guzzlers on the scrapheap.....hows a 1500cc pickup sound .....the first Ford Couriers were 1500cc,as were the first Hi Luxes......Ford used to call them "little buzz boxes" in the Ford F series. ads in the 70s.
