01-22-2021, 11:57 AM #101
Figures. Only the real studs had those.
Circular Slide Rules | Smithsonian Institution
You probably didn't know that condoms had serial numbers on them, either.
01-24-2021, 04:04 AM #102
You find lots of slide rules in chem labs, your normal looking one, duplex if you will, circular and there seem to be lots of tubular ones, popular with the older chemists, I don’t know how to work one properly, just manage a flat straight one, we had those in school, plus 4 fig tables and later 7 figure aka Naparian, ( each one with just about every formula known to man carefully inscribed between the columns and rows as an exam cheat sheet, the stationary shop was always out of mapping pens and drawing ink pre exam time.
Mark
01-24-2021, 09:12 PM #103
In one Star Trek episode there is the standard moment when Kirk says we will hit the atmosphere and burn up in 20 minutes and Spock says "I make it 20 minutes and 33 seconds, captain." The calculator he is holding is an E6B.
In the 50s I routinely carried a 6" Picket in my shirt pocket and used a Pickett Vector for serious work. It almost got me fired when I was doing accelerometer damping ratios. I would mount them on a shaker table and find the resonant point, then do a calculation from the shake displacement and the accelerometer reading. The calculation involves squaring a value. Normally we would test a batch and take the readings to the office where we ran them on a mechanical Friden. The 12" Pickett had expanded scales for squares and cubes so I could calculate the ratio to a close tolerance and fill out the sheets as I went. The Vice President of the company happened by, saw what I was doing, and threw a tantrum. I took my sheets in the office and got the same answers on the Friden, which only made him madder. He finally got fired, not soon enough.
Bill
digger doug liked this post
01-24-2021, 09:16 PM #104
Has anyone noticed what a remarkable thread this is. Thermite, Donie and Emanual Goldstein have not posted and it has not degenerated into obscene name calling.
BillLast edited by 9100; 01-25-2021 at 09:23 AM.
01-24-2021, 09:47 PM #105
01-25-2021, 10:45 AM #106
