rons
- Mar 5, 2009
- California, USA
Why have a metric size head on the oil drain plug?
Is it a standard size common to imports and domestics?
200 ford ranger 15mm socket. Ford is dumb about metric the truck is a mix of add and even sizes so you can not look and know what size wrench to use.
FYI I replaced the drain plug with a valve. Cost about $20. Makes it much easier and cleaner especially after I added a 90 degreee short hose on the outlet barb. Flip the lever and the oil drops straight down into the drain pan. Only the tips of my fingers get oily no oil running down my arms while the plug does not quite come out.
Bill D.
The US should have gone metric 50 years ago. Wait, when I was in school in the 60's & 70's this was going to happen. WTF did I miss??
Nothing pisses me off more than having to slide under my truck w/ a mix of metric & SAE tools. In-Ft-Lbs-slugs = maximum stupidity
Metric = smart!
That's very lose to 24mm.....Here's one for you; 1983 XR200R oil drain plug 61/64" Still have no idea why. And the Thread is Metric.
R
24.209mm is not the same and .0082" makes a difference---trust me. It baffled me for a reason, even thought "naw it's got to be round corners on the nut or something", right? Wrong. It is NOT 24mm.
Actually it's close enough that a 31/32" fits okay, but a little loose.
R
Notice
